Spring Code - Diesel Forum - TheDieselStop.com
Old 09-07-2005, 10:01 AM   #1 (permalink)
Spring Code
Gents-
Im trying to order 2 new rear spring packs for my 99 SD extracab--
I cannot find a sticker or lable with this code---
The numbers shoud be something like FFxxx RRxxx
my truck has helpers and the :i think: camper package? (sway bars)
1999 SRW Extra Cab, LB
Volant Air box, Magnaflow 4" SS turbo back,
Pre Pump Mod, EGT, ITP crossover tube, Dominator D-66 Turbo, Trans Go-Shift kit, DP Tuned 60/80/120/High Idle/economy/drive thru
www.beansdieselperformance.com
www.dptuner.com
SteedaJeff is offline
Old 09-07-2005, 03:57 PM   #2 (permalink)
SmokeyWren's Avatar
My Photos: (44)
Re: Spring Code
The spring code should be on the federal cert sticker on the lower doorpost behind the driver's door. That sticker has all sorts of info, including tire size and PSI, and SPR code.
The second letter of the spring code is the rear springs.
A = F-250, which needs part number YC35 5560 AC (LH/RH) for the spring pack and YC35 5588A (LH/RH) for the overload springs.
B = F-350 SRW, which needs part number YC35 5560 BE (LH/RH) for the spring pack and YC35 5588A (LH/RH) for the overloads.
(In later years, Ford put F-350 rear springs under F-250s, but I don't think they did that in '99. My '99.5 F-250 has code A rear springs.)
If you have a Dooley, holler back. And put which truck you have in your sig. [img]/ubbthreads/images/graemlins/cool.gif[/img]
SmokeyWren is offline
