1999-2007 General QuestionsGeneral questions related to 1999-2007 Super Duty trucks. If it doesn't fit the other categories, post it here. Gas engine discussion that pertains to all models is allowed. Specific gas engine questions should use the Gas Engines forum.
So I had to replace my Starter the beginning of this last Summer. No biggie, after that many miles I would expect things like that to need replacing.
My issue is now that it's getting cold in the mornings, the new starter is sticking, or not engaging the first couple of times I turn the key. Seems to finally 'unstick' and then is fine for the rest of the day. Only happens when the temp goes below freezing.
Can I spray the snot out of it with WD-40 to remedy the problem? Any body have a suggestion how I might be able to fix it, other than replace this one too? Of course I can't find my receipt to take this one back...
thanks
2001 F-250 Super Duty Crew Cab 285,000 miles AIS Intake
Starters shouldn't need any lube - if its sticking, don't risk damage to the flexplate, replace the starter.
New truck: 2002 PSD 4x4, CC, XLT, F350 dually. Air bags, 6.0 trans cooler, Fleetrite ELC, ISSPRO guages, DB HT starter (no more), Superchips 1705 tuner, Reese Titan, AIS, IPT pre-pump filter kit, in-tank mods, and much more to come.
Old truck: 2000 PSD 4x4, ext cab, XLT, F-350, auto, V-code springs, air bags, coolant filter, 203 thermostat, Fleetrite ELC, DB Alternator, DB high-torque starter, Tru-cool Max-cool trans cooler, B&M trans temp gauge, 47 gallon Titan tank, IPT pre-pump filter kit.
I'd count that one a loss and go buy yourself a DB Electrical hi-torque starter. The price for what you get can't be beat. Besides, their customer service is outstanding. I've dealt with them with a starter that was doing the same thing. Ended up getting a new one and never looked back. I've just bought an alternator from them so I'll keep going back to them again. Look into it.
As far as the starter not working, there could be a bad spot on the windings, or the solonoid is going bad. Who knows. Like dlblazer said, don't try to fix it. Replace it. It's not worth the headache.
__________________ '02 F-350 "Babe The Big Blue Truck" 4x4, Ext. Cab, 8' bed, SRW
'66 Bronco "Big Little Monster" - 5.0L EFI, AOD, 3.5" lift, 3" body lift, 35" BFGs, Lock-Rite front, mini spool rear, disk brakes, Warn Hubs
I would replace the starter with a hightork starter from DB electrical, a good value.
Sold 02 F350 Lariat CrewCab Toreador Red/ Silver DRW LB AT 4X4 4.10 gears, BTS custom chip, and tranny. built BTS and Ford Tough! 859,532 miles
SOLD: 02 F350 Lariat CC Toreador Red, DRW AT 4.10 gears, BTS custom chip, and Tranny 214,550 miles,Built BTS, and Ford Tough!
Sold 94 F350 XLT SC DI DRW 5Speed 314,000
Lifetime Member "BTS BUBBA" Association
"Ain't no feelin like BTS mobilin"
SLAPS Member
Sold 62 Corvair 95 Bus
92 Buick deuce and a quarter
03 Ford Windstar- Granny Hauler
