Steering box adjustment - Diesel Forum - TheDieselStop.com
Old 12-24-2008, 11:58 PM   #1 (permalink)
Hoss250's Avatar
I have been trying to fix the dreaded wandering problem of my 2001 F-250. Alignment has checked out fine, tires have been rotated, draglink ends and track bar have been replaced, balljoints are good, and everything seems tight. I moved to the steering box and noticed that if I grabbed the pitman arm it wiggled slightly. The pitman arm nut is properly torqued and loctited with the heavy duty red, but it seem as if the slop is in the sector shaft. My roomate's 1999 F-250 seemed tight, but I called a friend with a 2000 F-250 and his sector shaft wiggled slight also. My truck only has 56,000 miles, but all have been with 38 tires so the box could be worn or out of adjustment though it does not leak. I was hoping a few people could check theirs to tell me if it should have a slight amount of play (doesn't seem right) or should be tight. Thanks
2001 Black Standard Cab Longbed XLT 6 Speed Powerstroke 8 Inch Skyjacker 38 Toyos Welds Bilsteins Protech Stainless Box
Hoss250 is offline   Reply With Quote
Old 12-25-2008, 02:47 AM   #2 (permalink)
Sounds like the problem is in the steering gear, usually adjusting won't cure the symptons of wander.
Sold 02 F350 Lariat CrewCab Toreador Red/ Silver DRW LB AT 4X4 4.10 gears, BTS custom chip, and tranny. built BTS and Ford Tough! 859,532 miles
SOLD: 02 F350 Lariat CC Toreador Red, DRW AT 4.10 gears, BTS custom chip, and Tranny 214,550 miles,Built BTS, and Ford Tough!
Sold 94 F350 XLT SC DI DRW 5Speed 314,000
Lifetime Member "BTS BUBBA" Association
"Ain't no feelin like BTS mobilin"
SLAPS Member
Sold 62 Corvair 95 Bus
92 Buick deuce and a quarter
03 Ford Windstar- Granny Hauler
HighwayPrisoner is offline   Reply With Quote
Old 12-26-2008, 12:03 PM   #3 (permalink)
Banned
Depending on the cause of the wander, I beg to differ.... the number of success stories are significant. But one does need to be careful in the adjustment process.
GrampyJim is offline   Reply With Quote
Old 12-26-2008, 02:33 PM   #4 (permalink)
I should have said sometimes, instead of usually, and the care needed in adjusting. Thanks GrampyJim for the better explanation.
SLAPS Member
Old 12-27-2008, 08:01 AM   #5 (permalink)
There are many threads on adjusting the box. Be careful not to get it too tight. I raised the front wheels off the ground and had someone move wheels left to right and tightened until play was gone. Double check for play by moving the steering shaft by hand as you adjust. Just tighten until play is gone and no more. Move steering shaft by hand back and forth and visually watch the pitman arm for movement.
2003 7.3 F250 SD SRW Auto DIY intake 285/70 1.5" Leveling Kit TS Performance 75 HP Chip
TTBadDog is offline   Reply With Quote
Old 12-27-2008, 11:22 PM   #6 (permalink)
Banned
Originally Posted by Hoss250
balljoints are good
They might be too good....
A TSB (01-3-2) was issued for your '01 Super Duty due to stiff/sticky ball joints that caused steering wander and poor steering returnability.
You can check the balljoints by doing a steering knuckle torque to turn test. Basically you put the vehicle on an alignment rack, point the wheels forward, remove the tie rod from the knuckle and install a bolt/nut into the tie rod hole. Then with a click torque wrench attached to the bolt with it's handle straight forward, and set to 100 ft/lbs try to turn the wheel outward. If the wheel turns without the torque wrench cliking, then the turning torque of is acceptable and the ball joint is good. If the wrench clicks before the wheel turns, the balljoint is bad. Ford released new lower greasable ball joint (1C3Z-3050-AB), and the same uppers can be used (F6TZ-3049-AA). Torque the lower ball joint nut to 35 ft/lbs and torque the upper to 70 ft/lbs. Then advance the nut to the next slot to line up the cotter pin hole. Then retorque the lower ball joint nut to 140-160 ft/lbs. Grease em every 5K miles. If you use aftermarket greasable joints, be sure to install them per the aftermarket maker's torque specs.
Gooch is offline   Reply With Quote
