Steering box question... - Diesel Forum - TheDieselStop.com
Old 03-03-2005, 10:31 AM   #1 (permalink)
Anyone know how to tighten the internal components in the steering box? Maybe you can't, but mine is noticably lose.
Thanks,
Haubeil
2000 F350, extended cab, long bed, 4x4, complete 4" MBRP exhaust, ProComp 4", 35x13.5x18 MTZ, triple gauges (ISSPRO pyro, tranny & boost), Superchips Microtuner, Banks compressor wheel, Banks Quick-Turbo turbine housing, BigHead wastegate actuator, TransCommand
Haubeil is offline
Old 03-04-2005, 01:08 AM   #2 (permalink)
Banned
Re: Steering box question...
Find a workshop manual.... look up steering gear mesh preload adjustment over centre..... This is a crucial adjustment and, if botched, can make every ride a white knuckle ride. Misadjustment may leave you with a steering box that is near impossible to adjust properly.
I highly recommend becoming familiar with steering box basics before setting out on adjustments.
GrampyJim is offline
Old 03-04-2005, 01:00 PM   #3 (permalink)
fordmastertech's Avatar
This Thread will tell you how to do the adjustments. Like Grampy_Jim said these steering boxes can be easily messed up, I'll guarantee, you will not want to drive the truck if it is incorrectly set, it's a hand full.
[img]/ubbthreads/images/graemlins/shrug.gif[/img]
Excursion Pics
2000 Excursion Limited 4x4 Dark Satin Green Arizona Beige 7.3 DIT, AXDO, 3.73 LS, DP Tuner F5, TERMINATOR II w R-IPR, Adjustable Boost Regulator, Turbomaster, EBPV Delete, Air Dog, ITP Regulated Fuel Return, Fuel Cooler, Tags 1&2, Harpooned Tank, Magnaflow XL Exhaust w Aeroturbine 4040L, Sonnax/Tricumulator, 8 Autometer Sport Comp 4 Gauge A Pillar 4 Gauge Overhead, Ford APCM, Crimestopper Remote Starter With Remote Fast Idle, Ford AIS w Zoodad, W Code Front Modified B Code Rear springs, Rancho RS9000X, Rancho 5406 Stabilizer, Hellwig Rear Sway Bar, BFG Rugged Trail TA, V10 Trans Cooler w Dual Electric Pusher Fans, Coolant Filter, IAH Delete, (((XM))) Line Of Fire Light, Ford Cab Lights, 05 Headlights w GOS Conversion Harness, Jimmi Jammers, 03 Lighted Painted Tow Mirrors w C-BETR, PSD Badges, Pullrite Hitch, Prodigy Brake Controller, Born 01/29/00
fordmastertech is offline
Old 03-04-2005, 11:47 PM   #4 (permalink)
Thanks fellows!!! I greatly appreciate the head-ups!
...and Grampy_Jim,
LOL!! I can relate to a white knuckle ride. ...good choice of words!!
- Haubeil
Haubeil is offline
