steering problem - Diesel Forum - TheDieselStop.com
Old 05-01-2009, 11:16 PM   #1 (permalink)
steering problem
I have a 2000 ford super duty and steering is stiff and will not return to center and wanders all over road. i have replaced ball joints and had it aligned, replaced steering damper,adjusted steering box, and none of them helped. where should i go from here, steering box, pump, thinking of going with redhead steering gears any suggestions thanks
phiilipmcb is offline
Old 05-02-2009, 03:21 AM   #2 (permalink)
Ditto
I had the same issue not to long ago, except prior to that I had almost everything under the front end replaced under warr... I took it in, went for a drive with the tech... They replaced the box for the 3rd time in about 6 months. Prob solved.
04 X, 4x4, 6.0, V and Mod B codes, Rear Ford Sway Bar, Poly bushings front and rear on sway bar/end links.
Tony2Co is offline
Old 05-03-2009, 05:32 PM   #3 (permalink)
just had same problem ford put in A new steering box and that did nothing for the problem they told me nothing was wrong so I took the front end apart my self found one of my axle joints was stuck jack the truck up with front tires off the ground turn wheel side to side by the tire then turn the axle joint from 12 to 6 to 3 to 9 and see if you have A bad joint
2006 f250 6.0 is offline
