Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > General Questions
General Questions General questions related to 1999-2007 Super Duty trucks. If it doesn't fit the other categories, post it here. Gas engine discussion that pertains to all models is allowed. Specific gas engine questions should use the Gas Engines forum.
Old 08-06-2008, 08:41 AM   #1 (permalink)
LOOSEWHEEL's Avatar
Steering pull
Just throwing this out for opinions. My truck has developed a severe steering pull sort of like when you enter a road rut. It happens after making a turn. If I turn to the left, the truck will have a slight pull to the left. As soon as I correct to the right, the truck will pull severely to the right as if getting caught in a road rut. Any ideas? I am thinking loose track bar bracket, loose track bar or bad axle u-joint. Thanks!
2001 F350 CC SWB 6spd WHITE Loaded up incl. X springs.... a work in progress. 'Lo Rider' tonneau cover with electric open, Bedrug, Southbend Con OFe, DIY Tymar, 05 front conversion, Hog Performance 4" turbo back exhaust w/6" tip, Stock HU with 2 x JBL 10" subs, Infinity components (4), 1500W Infinity amp, 300W Precision Power 'Old school' amp, Bilsteins, DR 4.5" (6" lift total) and 37" TOYO AT'S on 17"x10" WELD Renegades.
Pics
Life is not a journey to the grave, with the intention of arriving safely in a pretty and well preserved body..., but rather to skid in sideways, thoroughly used, totally worn out and loudly proclaiming...
'What a trip!'"
LOOSEWHEEL is offline
Old 08-07-2008, 04:12 PM   #2 (permalink)
Supporting Member
missmanj's Avatar
same problems for about 3 months have not been able to figure this out either, still does it after i replaced shocks although i dont think shocks would have anything to do with it
2000 F250 7.3L 168,000
DP Tuner F5 Gauge Switch (Stock, High Idle, 40t, 80e, 140E, Lope Idle, 120R)
Rancho Nine Position RS9000XL Shocks
203* Thermostat
DIY Intake Napa 6637 Filter
CCV Mod
4" Straight Pipe Exhaust
ATS Turbo Housing
Powerslot Rotors & Hawk Pads
ISSPRO Gauges (Pryo, Trans, Boost, Water)
Turbo Saver
Max AC Assist
Stancor GPR
missmanj is offline
Old 08-07-2008, 05:00 PM   #3 (permalink)
BLOWINSMOKE99STROKE's Avatar
Well I Hate To Post And Not Have An Answer, But Let Me Know If Someone Has An Anwser, My Truck Is Doing It A Little Too, Not Really Bad Yet Though, Thank (whomever It Is You Thank) Because Taht Would Not Be A Fun Way To Pull Trailers.
EARLY 99 F350, CREW CAB, LONG BED. 4X4 7.3L AUTOMATIC. EDGE JUICE W/ ATTITUDE. 4" EXHAUST, NO MUFFLER, 6" TIP, COLD AIR INTAKE, "THROTTLE BODY SPACER" (ACTUALLY JUST AN INSERT IN THE INTERCOOLER LINE TO ROTATE THE AIR, probably doesnt even really work). DVD PLAYER, PS2, IN DASH TV, POWER INVERTER, 2-10" INFINITY SUBS IN PORTED BOX. CLASS 5 REESE TOW PACKAGE, FLIP UP GOSENECK HITCH. CB/PA, WITH DUAL TRUCKER WHIPS. TOW MIRRORS, AND CAB LIGHTS, BUG GUARD AND WINDOW VISORS. 285/75 BFG ALL-TERRAINS.
BD CCV KIT ON THE WAY!
LEVELING KIT AND BILSTEIN SHOCKS ON THE WAY!!
SOON TO COME: LEVELING KIT, 33X12.50 BFG ALL TERRAINS ON BLACK DICK CEPEK 17" RIMS, EDGE EVOLUTION PROGRAMMER (STACKED), HIGH PERFORMANCE HPOP, POSSIBLY 10" STACKS!
BLOWINSMOKE99STROKE is offline
Old 08-07-2008, 05:44 PM   #4 (permalink)
I,d be looking at the steering gear box ....
Or ball joint's rusted up....
Screwed up caster on the alignment can do it also ....
Rick.....
97 F 350 ...Lucky 13
"Most stuff's just stuck & needs hittin with a hammer"....
Supporter/End user of ShiftSolutions THE CURE E4/4R Trans Control. Helping Cancer patients and families
fordtransmissioncure.com
Special thanks to RacerX
racerxautomotive.com
action4478 is offline
Old 08-08-2008, 11:27 AM   #5 (permalink)
LOOSEWHEEL's Avatar
My axle u-joint is seized for sure. Even though it is free spinning, I think it catches once in a while enough to throw the steering out until it 're-centers' it self. Had a similar issue when the passenger side seized only it would not center and would create a horrible wobble. Kinda hard to explain. Ball joints are fairly new (greasable MOOG's 2 years ago). This all started after my lift install so I am not sure what the culprit is but the more I think of it, the more it points to the u-joint. A good way to tell is jack up the front, wheel off. Engage the hub lock and turn the hub. Should turn without binding as you steer left to right and back. Hope this helps others. The problem has not re-occurred for a few days and I have not replaced the joint yet to confirm. I hate intermittent problems.
Pics
'What a trip!'"
Old 08-08-2008, 03:40 PM   #6 (permalink)
scrapin's Avatar
Had a similar problem usually would happen after turning the truck would start jerking side to side. Occasionally it would happen driving, truck would jerk side to side. I had a bad Ujoint. I would check those and ball joints
1999.5 F350 Lariat 4x4 7.3 PSD tymar air intake, moog ball joints, rhino liner, 8 ft. min. mt. fisher plow ----- 3/04' 6.0 F350XL PSD 4x4 dually dump, moog ball joints, 9' min. mt.2 fisher plow
scrapin is offline
