Stuck in 4 wheel drive low gear!!! Help! I gotta get home!!! - Diesel Forum - TheDieselStop.com
post #1 of 9 (permalink) Old 07-28-2005, 10:57 PM Thread Starter
Went to pick up my boat from my parents place (40 miles from my house). Used 4 wheel drive low to pull it out of the lake because it is a very steep incline. Now I can't get out of 4 wheel or low gear! I checked every fuse I could see that made sense to check. No luck. I'd really like to get home tonight. Anyone have any suggestions???
erikjohnnelson is offline
post #2 of 9 (permalink) Old 07-28-2005, 11:05 PM
Pappy19's Avatar
My Photos: (6)
Re: Stuck in 4 wheel drive low gear!!! Help! I gotta get home!!!
Put the truck in neutral, turn the switch to 2wd and apply pressure to the brake pedal hard and steady until you hear it disengage. If it doesn't disengage you could have wound up the transfer case and may have to go in reverse for a ways and then try the same thing. If your vaccum was bad, you wouldn't be able to change to low range anyway, so it's probably just the above steps that should get you back in 2wd.
2002 F-350 SRW Lariat,4X4, PSD with too many goodies to list. 182k and a very strong 7.3. SOLD
2008 F-250, SC Lariat, 4X4,Shortbed, Pueblo Gold/black, V-10, 4.10, auto, Delivered on 9/7/07, great looking rig. South Texas bumpers front/rear, Air Raid Intake System, Diablosport Predator, Magnaflow, Husky's, JJ's, Ford alarm/remote start, Marathon seat covers, Sirius, PIAA, Access cover, Weatherguard tool box, Rhino liner, Michelins, Duraflap mud flaps, Escort 9500i, MagHytec rear dif cover.
2007 Lincoln LT (wifer's grocery getter),Superchip,Magnaflow duels, K&N dropin, Leer Browning Special
1996 Ford Bronco EB; almost stock
2007 Kubota 900 RTV diesel with goodies.
Pappy19 is offline
post #3 of 9 (permalink) Old 07-28-2005, 11:19 PM Thread Starter
Pappy ="s ROCK STAR!!!
Thanks! I'm heading home!!!
Erik [img]/ubbthreads/images/graemlins/smile.gif[/img]
post #4 of 9 (permalink) Old 07-29-2005, 07:43 AM
JimTJr's Avatar
My Photos: (20)
Just a question here,,
[/ QUOTE ] It would go into lo range ,,it just wouldnt have the front axles engaged,,right? The Transfer case is electricly activated. That is how some put the off switch on their vacume. So they can HAVE lo range 2wd....a mod I have read of on here....
Glad ya got it fixed.... [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
Jim T.*48* SLAPS Co-Founder, 30.8 yrs RETIRED UAW 6/01/06, Now an ART (Specialists Flight Chief) with the USAFR 414th MXS Seymour Johnson AFB.
New truck, 2011 F-350 SRW LB CC. White Platinum Lariat! 4x4
JimTJr is offline
post #5 of 9 (permalink) Old 07-29-2005, 02:50 PM
Pappy19's Avatar
My Photos: (6)
Don't feel bad, my son had the same trouble in his new Expedition and drove 32 miles in 4 wheel low along side of the road. When he got home and told me what had happened, I went out and in 2 shakes of a lambs tail, had him back in 2 wheel drive. He was very embarrased, but now he knows.
Pappy19 is offline
post #6 of 9 (permalink) Old 07-29-2005, 04:14 PM
JimTJr's Avatar
My Photos: (20)
32 miles,, at MAYBE 15mph?? That was a long ride,, huh?
JimTJr is offline
post #7 of 9 (permalink) Old 07-29-2005, 04:47 PM
My 99 had a quirk.. it used to switch from low back to high fine but suddenly it would just stick in low. I found that if I turned the truck off, then with the key back on and switch it to hi it would shift back into high no problem.
Randy
2005 4 door F250 Lariat, white with lear canopy.
faberbro is offline
post #8 of 9 (permalink) Old 07-29-2005, 05:43 PM
My Photos: (31)
Jim- I was at Pismo Dunes once and had it up to at least 50 in Low Range if I recall... That's getting up there in overdrive.
F250 CC PSD, 6-Spd, 4x4, DP Tuner 4 Pos Chip, 4 BD Cat Back, Cat Delete, 3.5 Down Pipe,
, ITP Fuel Sys,
, Home-made Headache Rack,
289 4-Speed 9"
Fat Diesel is offline
post #9 of 9 (permalink) Old 06-17-2014, 07:06 PM
colorado ford truck
Guest
Posts: n/a
Pappy19 is the man! Mine did the same, locked into 4x4low and that trick with putting it into neutral and pushing on the brake worked! Fantastic! Thank you, thank you.
