Stuck in low - Diesel Forum - TheDieselStop.com
post #1 of 11 (permalink) Old 12-16-2006, 02:24 PM Thread Starter
Stuck in low
I have my 2000 F250 Super Duty 4x4 stuck in low range. I have done the stop, neutral, select bit but nothing. I thought there might be a fuse/relay gone but cannot find a bad one. Is there any way to manually up shift this transmission (automatic w/odrive) into high range so I can drive it home? Thanks
usewillow is offline
post #2 of 11 (permalink) Old 12-16-2006, 03:07 PM
Re: Stuck in low
Try putting the truck in neutral, and letting the truck roll backwatds slightly. This should help relieve some of the "pressure" in the transfer case allowing you to shift out of 4 low.
Good luck,
Marc
2015 F 250 Supercab 4x4 Lariat long bed. Whelen M7's in grille, Whelen Inner Edge, Whelen custom interior rear lightbar/traffic advisor, Whelen Cencom Saphire controller, and other hidden emergency lighting, UWS cross box and custom bed cover
VTFireftr is offline
post #3 of 11 (permalink) Old 12-16-2006, 04:44 PM
Re: Stuck in low
IN addition to being stopped and in neutral, you have to have your foot on the brake.
Duncan
The 1997 F250HD Crewcab:
The 2000 XLT Excursion <font color="red">(SOLD)</font>:
The 2003 F250 Crewcab 6.0L:
The 6.0L Bible:
The 6.4L Bible:
frobozz is offline
post #4 of 11 (permalink) Old 12-16-2006, 07:52 PM
Re: Stuck in low
Did you get it to shift out of low range and make it home?
Joe
2002 F350, Crew Cab, 4WD, ISSOPRO Gauges,
3.73, Auto, 2wd low range mod, No door dinger,
Interior lights off switch, Zoodad Mod,
Extra Trans Cooler, Before coolers trans fltr,
Coolant fltr, Crimestopper remote start/alarm
Oil Guard Bypass, Air horns
MOUNTAINMAN444 is offline
post #5 of 11 (permalink) Old 12-17-2006, 12:31 AM
Re: Stuck in low
Had the same problem, after i had the trans replaced i was backing out of driveway and herd a clunk, transfer went into low and would not come out. The nylon gear on the transfer case that switches from hi to low broke and fell into low. That is what my mechanic told me had happen, replaced gear and everything is o.k.
99.5 (born 4/98)f350,cc,drw,4:10,airaid intake w/ k &n fitpac, straight piped ,pro,boost,tranny gauge,BRV+, ac mod.
garygaines is offline
post #6 of 11 (permalink) Old 12-17-2006, 07:19 AM
Re: Stuck in low
I've had issues with my truck in low also. My lever wouldn't budge out low so I rocked it back and forth tried different rpm's and gear selections. With two hands and a lot of vulgar language it got out. I think it might have something to do with my linkage.
01 F-250 Superduty XL 133,500 miles
31,500 miles on veggie
Ditched the Auto trans 4R100
6-speed Handrattla...
Clutch pedal
FASS pump
DP 80hp econo tune
Veggie oil undercoating and bedliner
Homemade veggie kit based on FN74
4" exhaust
DIY Tymar
tool box
rear springs
Shocks
275/75/16 BFG A/T's
203* T-stat
fuel pump
Water Pump
IDM
Dents
Rust
brakes
Front caliper
ball joints
all u-joints
2 fuses
more rust............
Spotty is offline
post #7 of 11 (permalink) Old 12-17-2006, 08:58 AM
My Photos: (12)
Re: Stuck in low
I think the original poster has the shift on the fly garbage. If thats the case it will be a slow ride home...................
11 F250 S/C 4x4 6.2 V8
94 F250 4x4 5.8 V8
01 Ford Ranger S/C 4x4 4.0 SOHC V6
92 Explorer Eddie Bauer 4x4 OHV
05 Expedition 4x4 5.4 3 valve.
Former trucks:
95 F350 CC PSD 5SPD Gear Vendors O/D 4x4
2003 F250 CC 4x4 6.0 HEADACHE! Traded before it blew!
89 F250 2wd 7.3 5spd with 256K when sold
94 F250 4X4 IDI Turbo 7.3 5 spd 160K when sold
95 F250 S/C 4x4 PSD 5 spd with 146K when sold
00 F250 C/C 4X4 PSD 6 Spd with 126K when sold (180K now)
mjstef is offline
post #8 of 11 (permalink) Old 12-17-2006, 08:03 PM
Re: Stuck in low
I suspect he is still trying to get home in low range, that's why he never posted back with the results. A couple of hundred miles at 30mph on the back roads (no expressways) would make for a long boring drive home.
Merry Christmas everyone, Joe
post #9 of 11 (permalink) Old 12-17-2006, 09:20 PM
Re: Stuck in low
I'd have that xfer case checked out, I just rebuilt mine and there are some plastic bushing things that is on the shifter and if those are wore out it you are going to have probs with shifting in and out of low, and if it's not fixed soon you will have to replace some gears etc......
2016 F-3506.7 PSD, Crew Cab, Long bed, Lariat with the Ultimate package, Fx4, Bench seat in the front, tan interior, white platinum with Caribou accent 5th wheel prep package, 3.55 rear end with Electronic lockers - Purchased New
2002 F-350 Crew Cab Long Bed, Lariat, 4x4, Automatic, , In-Tank Hutch Mod, Edge Insight Monitor. 320k miles
2000. Stock F-350 XLT 330K+ miles, white, 4x4, 6 spd manual, extended cab, Long Bed. Marinco Block Heater Mod, Tymar Intake. 4" Turbo Back Straight pipe, In-Tank Hutch Mod, Swamps Diesel 175/146 injectors - with TS Performance 6 position chip
jchipper is offline
post #10 of 11 (permalink) Old 12-17-2006, 10:05 PM
Re: Stuck in low
the motor that is on the transfer case is posably the problem.or a relay up in the dash.not easy to get to though and ford item only
2002 F250 superduty 4x4 psd auto supercab xlt.weight7020.vdh4.2004 mach 1 compition orange.
guss is offline
post #11 of 11 (permalink) Old 12-18-2006, 06:06 AM
Re: Stuck in low
...or simply step on the brake while trying to shift it! That's the one thing he didn't say he was doing and 99% of the time that is the culprit. I sure hope he comes back to tell us what happened...
Duncan
The 6.0L Bible:
The 6.4L Bible:
frobozz is offline
