Super tech Oil and Filter? - Diesel Forum - TheDieselStop.com
post #1 of 8 (permalink) Old 07-19-2007, 07:28 AM Thread Starter
indystroker's Avatar
Anybody running Super Tech Oil and Filter? Is it a very good product?When I used to mechanic about 5 years ago, the super tech brand was bottled by major companies. Oil was Quaker State, Filter's were STP/Champion, Antifreeze was Prestone and so on. Just curious to see if this was the case with the 15/40 diesel oil.
Indystroker
01 F-250 4x4, XLT, Crew Cab, AFE Stage II Intake
TS Chip w/ PHP Tunes, Auto Meter Gauges (pyro, boost, trans), ITP Fuel Tank/Pre-Pump Kit, Riffraff FRx, Gutted Turbo, Riffraff SS X-over, DIY CCV, 4" Turbo Back w/Donaldson M085171, Warn Hubs, Sonnax Kit
indystroker is offline
post #2 of 8 (permalink) Old 07-19-2007, 07:57 AM
Rich_Kimball's Avatar
Re: Super tech Oil and Filter?
I had a report that the SuperTech ST3786 filter was manufactured by Mobil, in that it was the same one marketed under the Mobil 1 brand. I have been using them as the Mobil 1 filter claims to be a better filter than most.
Since Wal-Mart sells lots of Shell Rotella-T, my best guess is that the ST 15w40 diesel oil is also same. I don't use it as my truck likes Mobil Delvac better. I have used the ST oil and have had the same oil consumption issues that I have with Rotella-T.
Happy trails,
Rich Kimball
Went to new owner on 12/12/09 (I will miss her)
2000 F350 XLT CC LB SRW 6spd 4x4 Toreador Red
'08 Center Console,Ranch Hand Grill Guard, SBC ConO clutch,DP Tuner (60T,80E,120R),Gauges,Ford AIS,Walker BTM,AIH delete,HPX Oil Crossover, Wicked Wheel,TurboMaster WG Contoller,Riley BRV+,Riley Boost Boots,EBPV Gut w/mod. pedestal,IH Bellowed UpPipes,Final Charge ELC coolant w/heater bypass,Riley Coolant Filter,Ford AIC,Centramatic Wheel Balancers,115gal Aux tank,Firestone airbags w/cab control. Oilguard Bypass Filtration,DFA 'Cross Connect' Fuel Lines
Rich_Kimball is offline
post #3 of 8 (permalink) Old 07-19-2007, 09:26 AM Thread Starter
Thats kinda what I was thinking. I'll give it a shot and see what happens.
Indystroker
post #4 of 8 (permalink) Old 07-19-2007, 10:40 AM
Not necessarily so. They may even use different suppliers in different areas of the country. However, it would all be manufactured to Walmart's specs, which would probably the proper API classification and viscosity for your vehicle. Also, it may or may not be as good as the manufacturing company's own branded oil.
As far as the oil filters, a few years ago, Motorcraft filters tested out the best. For a few bucks, I won't take the chance using a cheap filter. BUT, I don't drive my Diesel very much, so oil and filters are not a major annual expense for me. Your case may be different.
2003 KR F-250 4X4 CC SWB, 6.0, 5 Speed Auto, 3.73 Axle, no Limited slip. Rhino bedliner, Unicover bed cover.
Built on February 19, '03
#2 93 F-150 XLT, 5 Liter, Auto, 4X4, X Cab. 251,000 miles. Uses no oil between changes.
montanafan is offline
post #5 of 8 (permalink) Old 07-22-2007, 07:38 AM
There has been lots of discussion on BITOG in the past about who produces Supertech oil. Wal-mart is so big that it depends on what region you are in.
In the midwest it is likely Warren, and elsewhere it could be another producer like Conoco, but I am pretty sure it is not Shell, the producer of Rotella.
You can tell the Warren jugs by looking on the bottom of the jug and if it has WPP embossed in the plastic it is a Warren product. Also there are two Warren's, the supertech is Warren Performance Products I think, not the other one. Either way it really is pretty good stuff for the price. You can go to the Walmart site and find the MSDS's for the Supertech 15w-40's, and there will be two different ones, one from each supplier, to find out positively who the other supplier is.
reyjay is offline
post #6 of 8 (permalink) Old 07-22-2007, 07:44 AM
PS. supertech filters are made by Champion Labs, who also produce the M1 filters, but they also produce a lot of other filters for different brands as well.
That does not mean that you will get the same filter material of even construction as a M1 filter, as they have many different lines and different filter media's that, as montanafan says are used to customer specs.
reyjay is offline
post #7 of 8 (permalink) Old 07-22-2007, 08:18 AM
NCHornet's Avatar
Even if ST was made by Shell, which it isn't, doesn't mean it would be the same as Rotella!! The same goes for filters and other products. You need to look at the spec requirements in your owners manual. if the oil meets or exceeds these specs it is okay to use. Only UOA's will determine if your truck like it.
NCH
2000 Ford F350 4X4 Auto,Crew Cab Lariat, Western Hauler Package, Long bed,
Isspro EV Guages on A-Pillar, Coolant change from Green to Gold to Red,
SCT XCalibrator2 with DP's 60 tow,80 econo,120 Race
Fumoto Valve, Marinco Mod, Homemade CCV MOD,Fuel Neck Mod, KMC Wheels at all 4's
Monroe Reflex Shoxs, SS/Kevlar Brake Lines,
FTVB from Greg Evans,Ford AIS Intake
Coolant filter,Walker BTM, Attwood Gooseneck ball flush mount,6.0 cooler, 2002 headlights & corners
Zoodad Mod,Cyro'd Powerslots and Hawks LTS Pads. 2005 front grill
Turbo Lifesaver, Infinity Refrence x4, powered by Infinity Reference amp, sounds awesome!!
Towing a 2005 HORNET 30BHSS 8500 LBS,
Stopping it with a Prodigy P3 Controller
Friends Don't Let Friends Drive Trucks With Generic Tunes!!
NCHornet is offline
post #8 of 8 (permalink) Old 07-22-2007, 08:31 AM
I don't think I'd assume that because the container was "such and such" that the contents were "such and such".
Several years ago, when I was working at the Shell Martinez refinery, we got a railroad tank car of Pennzoil that we packaged in their own containers for them. I guess what I am saying is that Walmart MAY supply the containers to the refiner. (or may not) I don't know.
However, any Walmart oil would meet specs supplied to the manufacturer by Walmart, who does have a reputation to uphold.
