Symptoms of bad ball joints? - Diesel Forum - TheDieselStop.com
post #1 of 14 (permalink) Old 07-19-2007, 11:59 AM Thread Starter
What are the symptoms of bad ball joints? I have a 2006 F250 with about 24000 miles on it and my recent trip up north I noticed a slight "klunking" noise and a rattle if I hit a bump in the road.
Additionally, what parts would you recommend I ask for if I decide to pay for the work to be done?
Smooth seas do not make good sailors...
Malindor is offline
post #2 of 14 (permalink) Old 07-19-2007, 01:37 PM
Re: Symptoms of bad ball joints?
Malindor,
Not that I consider myself an expert of any kind, But I did have new Upper & Lower Ball Joints installed on my 03 F-250.
My truck had 135K on the clock when I had them changed out and I would be SHOCKED if your truck with only 24,000 miles actually needed new ones.
It may just need some adjustments made to other steering components.
But IF you find that it need them, I encurage you to replace them with MOOG brand parts.
Why, because the O.E.M. parts do NOT have any grease (Zirc) fittings on them.... [img]/ubbthreads/images/graemlins/eek.gif[/img]
The MOOG's come with grease fittings installed and will allow them to be lubed and therefore extend the life of the joint.
JR44
2003, F-250, 6.0L PSD, Torqueshift, CrewCab, XLT,FX4,Short Bed, All Black Sport Model, Sunroof, Line-X Bed Liner, AFE Stage1 Pro-Guard 7, DPPI/MBRP T-304 Stainless Turbo-Back Exhaust, complete with CNC machined collar!
Banks Tecni-Cooler, Front,Rear Diff & 5R110 Mag-Hytec Pans, AutoMeter Cobalt Boost,EGT,Trans Gauges on A-Pillar, Bridgestone 285 Revo's, Bilsteins,SSBC V8 BRAKE CALIPERS, POWERSLOT CRYO ROTORS, Lund Smoke Bug Shield and Weathertech's AeroVisors on all windows. 16YR N.R.A. member, 14YR D.U. member, 10YR N.W.T.F. member. 5YR Delta Waterfowl member.
warrenpouyer is offline
post #3 of 14 (permalink) Old 07-19-2007, 03:22 PM Thread Starter
Thanks for the opinion; I am going to bring it in this weekend and have it checked out. I sure hope it isn't the issue that I fear, becasue money is rather tight these days, lol!!!
But I was a little concerned that I may have caused some damage, as I do spend about 40% off-road traveling to various trail systems and thought I might have damaged it there.
Malindor is offline
post #4 of 14 (permalink) Old 07-19-2007, 04:47 PM
Malindor,
Jack up each front wheel one at a time. Grab the tire high and low and see if there is any movement. If there is any movement then the ball joint is most likely bad. If there is no movement when using your hands, you can take a pry bar and have someone pull up on the wheel while you look at the ball joint underneath. Again, any movement means it's bad.
Yes, your ball joints can be worn just after 24K especially if you do the off-roading you indicated. It seems Fords are famous for ball joints going bad with no rhyme or predictable pattern as to when they wear out. Some people get your mileage out of them while others get over 100K. My right side ones went bad after about 50K. As JR44 says, I had mine replaced with Moog greasable ball joints. They had to grind down the top of the the top fitting to keep the axle knuckle from hitting it. What a difference after the job was done. The truck drove better, braked better, and the noises were gone.
My left sides are still OEM and have about 80K on them. The only thing I can figure as to why the rights went bad first is because the right side of the road is where most of the potholes and road patches are located. One last thing, if you do get the greasable ball joints make sure you grease them with the wheel jacked up.
John
2003 F350 6.0 PSD 4X4 SRW
Engine13 is offline
post #5 of 14 (permalink) Old 07-19-2007, 05:21 PM
I got a "clunking" noise when I would pull forward or back up..... at roughly 47k miles they were replaced, and they were making noise well before that before i figured out what it was.
2004 F350, 6.0, crew cab, long box, ISSPRO BOOST-EGT-PYRO gauges, 4" MBRP exhaust, Innovative Diesel SCT programmed, GOS Racing headlight harness upgrade w/Bright Box FLC, husky floor mats, LEER canopy, FabTech 3.5" hangers on 35" tires.
2001 GMC Yukon, all stock besides the 18" chrome wheels and the kids car seats.
1992 Toyota Terdcel.
2006 Desert Fox toy hauler.
2005 Yamaha YFZ450 - a toy for the sand.
1996 Yamaha Banshee - oh yeah, it's a ride in the sand!
Richman is offline
post #6 of 14 (permalink) Old 07-19-2007, 11:07 PM
Like JR44, I'm no expert. mine was a broken bushing on the stab.bar
Graduate of University of Science Mathematics Culture.
04, PSD, 250.
chinkman767 is offline
post #7 of 14 (permalink) Old 07-20-2007, 10:12 AM
stevedunham's Avatar
My Photos: (6)
My '04 developed a drivers side "clunk" too and I did all the typical troubleshooting you read here... Tightened the sway bar end links, checked all the front suspension nuts and bolts, etc. Then one day not too long ago, I was doing a tire rotation and noticed the Drivers side front lower ball joint was loose and most likely the culprit. Simply jack up the front axle, support it with jackstands and grab the tire top and bottom and see if you can cause any movement. It was pretty obvious on mine and I had less than 40,000 miles on the truck. I decided NOT to have FORD replace them under warranty because I didn't want the same junk under there to have to fix it again down the road. I did the job myself, replacing the upper and lower ball joints on both sides ( Passenger side lower was also shot ) and the only special tool I needed was a ball joint press I borrowed from Autozone. I bought TRW lifetime warranty joints which come with zerk fittings so I can lube the BJ's every time I change the engine oil.
** SMD '04 F250 6.0 CC King Ranch, '14 F350 6.7 Lariat CC **
Original engine grenaded @ 31,000 miles..! Replacement engine DIY bulletproofed, Gen 4 Injectors, 58V FICM, Blue Spring, IPR Remote Oil Cooler/Coolant Filter, ARP studs, DC Power 270 Amp Alt, BD billet H2O pump, CCV catch can, MBRP Duals, 2 blown Turbos currently running a Garrett, DR Edge 8.5" hybrid lift w/ 5" rear leafs, 37x13.5x17 Swamper M16's, Draw-Tite portable winch mount, WARN xD9000i, WARN Pocket Flares w/ Durabak, 4.56's w/ F&R ARB's, Dynatrac Dana 60 35 spline stubs, Powerslot Cryos/Hawk LTS, Yukon Hardcore 35 spline hubs, 2" wheel spacers,
stevedunham is offline
post #8 of 14 (permalink) Old 07-20-2007, 10:31 AM Thread Starter
Thanks for the excellent advice. The trouble-shooting procedure sounds rather easy as I do have a decent jack and stands. I will check this out over the weekend to see if my suspicion is correct. I am positive it started on the last trip as I was on some pretty rough terrain.
Unfortunately, I will most likely have to pay someone to do it as my tool collection is rather sparse. Most tools I have are specialized for my 2-stroke dirt bike.
Malindor is offline
post #9 of 14 (permalink) Old 07-20-2007, 02:39 PM
JimTJr's Avatar
My Photos: (20)
IF you pay someone to do this job, be prepaired to spend over 1,000.00!
OK?
Couple of quotes when mine were bad, cheapest was almost 1200.00 from Firestone...
Did it myself on my 99,,,,
Jim T.*48* SLAPS Co-Founder, 30.8 yrs RETIRED UAW 6/01/06, Now an ART (Specialists Flight Chief) with the USAFR 414th MXS Seymour Johnson AFB.
New truck, 2011 F-350 SRW LB CC. White Platinum Lariat! 4x4
JimTJr is offline
post #10 of 14 (permalink) Old 07-20-2007, 02:51 PM
I'm going to swap out all 4 on my truck tomorrow along with the u-joints. Wish me luck!
2002 F250 Crew-Cab Short-Box 4x4 Off-Road 7.3L
283 HP/ 570 Lbs/Ft
BTS Trans
BTS 4-Stage FlipChip
AFE stage 1 Intake System
Silverline 4" T-304 Stainless Turbo-Back Exhaust-Donahoe Racing "Edge 4.5" Plush Ride lift
BFG all terrain 35" tires
Niner1190 is offline
post #11 of 14 (permalink) Old 07-21-2007, 10:21 PM
Arent you still under the 3yr/36000 mile warranty? Or are ball joints considered a wear item like brakes?
2007 Ford F-350 XLT 6.0L Diesel Reg Cab SRW Stock Red Clearcoat. Line-X Bedliner, Back Rack.
gillettebeanz is offline
post #12 of 14 (permalink) Old 07-21-2007, 11:25 PM
Did mine today, no air tools, in the driveway, 90 minutes jack to jack. Including waiting on the rain shower.
Andy
Early 99 5-98, F350 extended cab, DRW LB 245,000 miles and counting, Hood insulation delete (Soaked with fuel), Hutch mod, Harpoon mod. Otherwise, pure stock (for now)
You only need two tools: WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
arisley is offline
post #13 of 14 (permalink) Old 07-24-2007, 03:32 PM
A few additions - When my 4wd F250 started rattling/clunking at 28k on washboard roads I figured out that it was the front swaybar endlinks. Disconnect one endlink and then try to shake it, if there is any play it will chatter on rough roads. Energy suspension kit is only ~$40 to fix it.
I just found out yesterday that now my balljoints are shot at 60k miles. Truck was going along fine, started pulling to the right, now clunks so loud and pulls so bad under braking I won't drive it. Happened all in ~300 miles. Time to figure out how to get it into my garage!
-C
cbombara is offline
post #14 of 14 (permalink) Old 07-27-2007, 02:54 PM Thread Starter
Well, it looks like it was a bad bushing on the sway-bar. Thought I would update ya all, since you were very helpful in your suggestions.
Malindor is offline
