telescoping mirrors stuck - Diesel Forum - TheDieselStop.com
Old 10-31-2009, 05:48 PM   #1 (permalink)
my mirrors are stuck in the widest position. can these mirrors be disassembled, freed up, then lubed? it doesn't look to me like the come apart, but somebody else may know better.
tinkerr is offline
Old 10-31-2009, 09:40 PM   #2 (permalink)
What year is your truck?
2006 KR, CC, LB, 4x4, 6.0 moonroof, power rear slider, dual alternators, Pop-Up gooseneck ball, DR leveling kit, 60000 miles, 285/75/18 Toyo ATs
12/98, CC, XLT, LB, 4x4, 7.3, 6sp, '06 front end, 4" front springs, Bilsteins, DiPricol Pyro,Boost and Fuel Gauges, 35" Toyo, SouthBend Con-O, 185,000 miles, 4" exhaust, Performance Friction rotors and pads, DP F5 chip, RedHead steering box
BWD Turbonetics .84 Quickspool Turbo/Spearco
EBPV Deleted
Dieselsite BRV+, Intercooler boots
Banks Tubes
Terminator
ITP Reg. Return, Intank, and Delete
2008 Hudson 7 ton GN
2002 JCB 212s
2004 A300 Bobcat
barnbuilder is offline
Old 11-01-2009, 10:29 PM   #3 (permalink)
I gotter figured out. the mirror portion is removable, which gives you access to the screws to remove the back. putting the mirror portion back in place is a little more challenging though.
tinkerr is offline
Old 11-02-2009, 10:02 AM   #4 (permalink)
I would have just sprayed a little PB Blaster in the slide grooves and pounded them in.
2001 F-350 Crew Cab XLT PSD 4x4, Long Bed, 6-speed, 3.73, Manual Transfer, Power TTT Mirrors, 122k miles.
1989 Toyota 4x4 xtracab SR5 V6, Beat to heck with 200k+ miles and still running strong.
catch&release is offline
