Thef broke my door lock? - Diesel Forum - TheDieselStop.com
Old 12-03-2008, 11:54 PM   #1 (permalink)
Unhappy Thef broke my door lock?
I was at the store and some a#$ hole with a hamer and flat head screw driver pop my lock ran sacked my truck. I cant lock my door now is this an easy fix, or is this going to cost alot of money.
Kevin73 is offline
Old 12-04-2008, 08:09 AM   #2 (permalink)
I am starting to think it is easier to just leave the truck unlocked and get a quality lockbox to safeguard valuables. This way they don't f-up your truck breaking in. I would think a junkyard would have all those parts for your door...good luck. Also consider jimmy jammers? for the future.
02 SWB CC 4x4 auto, AIS, DPTunerF5, FTVB, 4" Banks Monster SS Exhaust, HPOXover, AirDog, Amsoil ByPass, Centramatics
blackout is offline
Old 12-04-2008, 12:16 PM   #3 (permalink)
Sorry to hear it. Join the crowd. Someone broke into mine 3yrs ago and stole my .357. I ordered a new handle from Powerstrokeshop.com. Not hard to put in would be helpful if you have small hands, arms and are double jointed.
You'll need a new lock and have it keyed to match.
2006 KR, CC, LB, 4x4, 6.0 moonroof, power rear slider, dual alternators, Pop-Up gooseneck ball, DR leveling kit, 60000 miles, 285/75/18 Toyo ATs
12/98, CC, XLT, LB, 4x4, 7.3, 6sp, '06 front end, 4" front springs, Bilsteins, DiPricol Pyro,Boost and Fuel Gauges, 35" Toyo, SouthBend Con-O, 185,000 miles, 4" exhaust, Performance Friction rotors and pads, DP F5 chip, RedHead steering box
BWD Turbonetics .84 Quickspool Turbo/Spearco
EBPV Deleted
Dieselsite BRV+, Intercooler boots
Banks Tubes
Terminator
ITP Reg. Return, Intank, and Delete
2008 Hudson 7 ton GN
2002 JCB 212s
2004 A300 Bobcat
barnbuilder is offline
Old 12-04-2008, 12:22 PM   #4 (permalink)
socalgn's Avatar
My Excursion was broken into a couple of years ago- same method.
I tore into the front doors, removed both lock cylinders and accompanying linkages, and filled the holes with spray foam. Not fancy, but it hasn't been broken into since.
2002 Excursion 7.3 [B] sold
1999 F-250 SC SB 4X4 auto - sold
2006 Dodge Magnum SRT - wagon from hell!
stock..not!
450hp station wagon...good stuff!
socalgn is offline
Old 12-04-2008, 03:22 PM   #5 (permalink)
They got me as well. I still have not replaced the handle. Post up a link to one if you find it. I will be bolting a lockbox in the bed soon. I have a bed cover so it won't be seen.
2002 F-250 Crew Cab Long bed 7.3 4x4. Edge w/attitude, Edge Evolution, Triple disk converter, whicked wheel, 203 t-stat, High pressure bypass, BTM, lifted sitting on 35's. Onboard Air, tank, train horns, air bags w/ controller. Custom 86gal AUX tank, Tonneau cover, Dual Din in-dash DVD/NAV.
02Boathauler is offline
