Third Dead Alternator in 3 Years! - Page 2 - Diesel Forum - TheDieselStop.com
Old 01-19-2010, 04:07 PM   #16 (permalink)
Gyro, fwiw, I changed my alternator and batteries out 4 years ago. I went with a new (not rebuilt) alternator from O-Reilly's (and their batteries), and I haven't had one hint of a problem. I'm not sure what the difference is between the 7.3 and 6.0 alternators, but I think I only gave around $179 for the new alternator. I drive everywhere with my headlights on, but I don't haul much. I wouldn't think the extra drain from your 5th wheel lights would amount to much (unless the charge circuit for your trailer battery is draining the alternator down good), but I would definitely step up to a higher output alternator. You could check to see what the oem alternator output vs an alternator from a 6.0 with ambulance package would be.
For a long time, DBelectric was the premier place to buy an alternator from, but I've read enough posts over the past year to sway me to buy locally, if I can find what I need.
If you have the chance, you might take your alternator to an alternator shop to see what it would cost for them to rebuild your alternator with a higher output capacity (if it's possible).
I've got the AIC in my 2000, and it's nice to be able to push a button to see what your truck is doing. Having the charge protection on it is doubly nice, so I can set the AIC to high idle when I need it to, or watch the battery charges if I start running things off of the dc-ac inverters.
just my .02 cents worth
short_stuff
Y2K F250 CC PSD Auto, Short-bed Lariat, Woodland Green/Gold, ordered 07/10/99, born 09/12/99, delivered 10/08/99, Access bed cover, Bed Rug, Zoodad mod, Viper Remote Start Alarm, Fumoto valve, 103K somewhat error-free miles (so far) [never back to dealer for anything]
Repairs: CPS, Water Separator Valve assembly, rear axle bearings, VSS, batteries, brakes, alternator, serpentine belt (x2), driver door pwrlock actuator, water pump
2009 VW Tiguan 2.0 l turbo 200 hp gas engine (TDI engine not available for it yet)
short_stuff is offline
