Tire wiggles side-to-side. Ball joints or tie rod ends? - Diesel Forum - TheDieselStop.com
post #1 of 3 (permalink) Old 07-30-2009, 06:25 AM Thread Starter
Send a message via MSN to texas_psd
Hi Everyone,
I am trying to track down a front-end problem on my '03 6.0L FX4 with 155k on the clock. My problem is a "scrunching" noise during suspension compression and a slight pop when I turn.
I jacked the front-end up to check for tire or suspension play, thinking I have bad ball joints. There is no movement if I put a pry bar under the tire and push upward, nor does the tire move if I wiggle it from top and bottom. However, I have a fair amount of play if grab it on the sides and wiggle left to right/side-to-side.
I can't find much when I search, probably because I'm not searching the right keywords. Is a left-to-right/side-to-side wiggle bad tie rods or bad ball joints? Thanks in advance for the input!!
2006 Ford F-250 FX4 CCSB
Go: 6" Fabtech suspension lift, 20" Procomp Series 6001 wheels with 325/60-R20 Nitto Terra Grapplers, SRL Tune, Edge Insight CS
Show: Leer 700 Tonneau Cover, Pioneer X920BT Navigation, 8" JL Audio sub, Viper alarm/remote start
texas_psd is offline
post #2 of 3 (permalink) Old 07-30-2009, 10:26 AM
Leroux's Avatar
The best way I found to find a loose joint was have somebody get in the truck and turn the wheel side to side why I look under the front. Most of the time you will be able to see whats causing the slop.
2000 F250 Lariat, CA Emissions, CC, Long Bed PSD, 4x4, Manual, 4.30 gears, 102K Miles
Performance Mods: Tuned by PHP, Gauges, AIH Delete, 5" straight exhaust, DIY Intake
Suspension: Fabtech all spring 8" Lift, Fabtech Dual Front shock mounts, Fabtech Dual steering stabilizer, Bilstien 5125 on corners, 17" ATX Vice, 37" Toyo M/T
1995 Ford F350 PSD
Leroux is offline
post #3 of 3 (permalink) Old 07-30-2009, 10:37 AM
Todes's Avatar
a side to side wiggle in most cases is a tie rod......
When looking for ball joints I jack the front of my truck up and grab the bottom of the tire and pull back and forth....no play=good ball joints
Then i grab the sides of the tire (steering locked) and wiggle side to side and if there is a considerable amount of play I'll wiggle it again and look at the tie rod ends
7.3L Stroken 4 life!!!
STOLEN 12/14/14
- Recovered 12/16/14 (let the rebuild begin): 2002 F-250 4x4 7.3L Powerstroke 240K(12/2014) (Custom Headache Rack with Bed Rails, lost to theft)
Todes is offline
