Torque Specs for Lug Nuts - 06 F250 - Diesel Forum - TheDieselStop.com
post #1 of 6 (permalink) Old 09-11-2007, 04:22 PM Thread Starter
friscocrownie's Avatar
Would anyone happen to know what the lug nut torque specs are for an 06 F250? Swapping out my OEM 18 inch wheels for the OEM 20's.
2008 F250 Harley Davidson Edition
friscocrownie is offline
post #2 of 6 (permalink) Old 09-11-2007, 05:09 PM
Re: Torque Specs for Lug Nuts - 06 F250
I called discount tire today for the same question and they said 150 ft lbs. Seems a little high to me. I went 120.
Sheff
Dave Sheffield
06 F250 6.0 4x4
Sheff is offline
post #3 of 6 (permalink) Old 09-11-2007, 05:19 PM
klhansen's Avatar
My Photos: (180)
I would think that the torque should be the same as the earlier models. Ford sent me a revision to my owner's manual that revised the lug nut torque up from 100 ft-lb (IIRC) to 160-170 ft-lb. Check your owner's manual. It should be in there.
Don't guess. You might not want to see one of those wheels passing you on the highway. [img]/forums/images/%%GRAEMLIN_URL%%/eek.gif[/img]
), AIS,
regulated return,
klhansen is offline
post #4 of 6 (permalink) Old 09-11-2007, 07:12 PM
SmokeyWren's Avatar
My Photos: (45)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Sheff</div><div class="ubbcode-body"> I went 120.
Sheff </div></div>
You screwed up. Increase the torque before you lose a wheel.
For my '99.5, Ford says a minimum of 155 lb/ft if you are unloaded and a slow poke. But when loaded or going faster, you need 165 lb/ft. Since I'n never unloaded and certainly not a slowpoke, I have mine set at 165 lb/ft.
But for the later models, Ford simply says 165 lb/ft:
<div class="ubbcode-block"><div class="ubbcode-header">Code:</div><div class="ubbcode-body ubbcode-pre" style="height: 150px;"><pre>
2008 F-Super Duty 250-550 Workshop Manual
SECTION 204-04: Wheels and Tires
SPECIFICATIONS Procedure revision date: 01/02/2007
Torque Specifications
Description Nm lb-ft lb-in
8-Lug F-250/350 224 165
10-Lug F-450/550 224 165
Sensor band (worm gear) 3 27
</pre></div></div>
SmokeyWren is offline
post #5 of 6 (permalink) Old 09-11-2007, 09:13 PM Thread Starter
Thanks for the replies, appreciate it!
post #6 of 6 (permalink) Old 09-12-2007, 06:58 AM
Up up and away it is. Thanks.
Sheff
Dave Sheffield
06 F250 6.0 4x4
Sheff is offline
