Trailer wiring plug - Diesel Forum - TheDieselStop.com
Old 10-08-2008, 11:36 AM   #1 (permalink)
Question Trailer wiring plug
I've searched and searched so sorry in advance if this is redundant, but I need some help.
I've got to replace my factory trailer plug setup on my 2001 F350 SC. I've bought a replacement 7/4 pin plug and mount and I've disconnected my old plug. On the truck side of the OEM harness there is a plug that is used so you don't have to splice wires. Problem is there is a black wire with a green stripe in the harness and I haven't the foggiest clue what it should connect to. On my new plug I have a purple wire that is indicated to be reverse (I assume back-up lighting). Is that what I should connect the odd black/green wire to?
Thanks in advance!
-Arlie
sdf350arls is offline
Old 10-08-2008, 02:50 PM   #2 (permalink)
Yep, the black wire with the green stripe is back-up lights in your factory harness and would normally go to auxillary circuit (center pin) of your 7 way connector. Of course if you have no use for back-up lights on your trailer you can make the center pin anything you want, like an aux. hot 12 volt feed, etc.
2006 F-350 DRW, 4X4, 6.0L PSD, 4.10 LS, Tow Command, Reese 20K, Firestone Ride-Rites, Auto Meter 3 guage A-pillar mount, American Tank 45 gal. aux. tank/toolbox, Rhino-Liner, Pro-Flaps, C-Betr mirrors.
2008 Cardinal 37RL 5th wheel
truck pics
2004 Cardinal 5th Wheel pics
Fordman6 is offline
Old 10-09-2008, 01:56 PM   #3 (permalink)
Cheers!
Exactly what I needed to know thanks!
-Arls
Old 10-09-2008, 03:40 PM   #4 (permalink)
Not just for reverse lights though. On my boat trailer, when I put it in reverse, that signals the brakes to let up so the trailer can back up, otherwise I have to turn a release lever on the trailer.
2001 Silver F-250 7.3L 4WD, extended cab, 130k miles, BF Goodrich A/T 285/75; BTS auto tranny w/6.0 cooler, AIS severe duty intake and filter w/Zoodad mod, 6 position chip from BTS, 4" turbo-back exhaust, Magnaflow muffler w/5" tip, Speedliner sprayed-in liner, Monroe Reflex shocks, Isspro pillar gauges
sparvin is offline
