Turn signal relay - Diesel Forum - TheDieselStop.com
post #1 of 6 (permalink) Old 10-19-2012, 12:51 PM Thread Starter
Turn signal relay
The other day my left turn signal started blinking rapidly and the rear trun signal stopped working while the front still worked. 2 days later the right did the same thing.
I'm thinking it might be the multi function switch or a bad wire in the column. Anyone have this problem before? This is for my 2004 F350.
Dave
2001 F-350 XLT SRW 4x4 CC long bed. 315k miles. Banks 4" exhaust, Air Raid intake, Pro Guard 7 filter, cold A/C mod, EBV mod.
2004 F-350 Lariat SRW 4x4 CC long bed. 47k miles. 4" exhaust, cold air intake, Pro Guard 7 filter ARB air locker.
skydive is offline
post #2 of 6 (permalink) Old 10-23-2012, 09:31 PM
klhansen's Avatar
My Photos: (180)
Usually the rapid blinking is because one of the bulbs on that side burnt out.
Did you check the bulbs that "stopped working" to see if they were burnt out?
Simple fix. Change the bulbs.
), AIS,
regulated return,
klhansen is offline
post #3 of 6 (permalink) Old 10-24-2012, 12:02 AM
Rich D's Avatar
Sounds like the multi function switch for sure. You might get it to work again by rapidly pulling the arm towards you, a few times, like you were flashing the high beams. This might help clear up the bad contacts not making up within the switch.
Early 99 F250 XLT,White/Silver,4x4,SC,SB,A/T,PMT1,ARE LSII tonneau,Amp Research power steps,MB Razor's,295-60-20 Nitto Trail Grapplers,Rhino Liner,Rancho9000's,Bushwacker Street Flares,DP-Tuner F5,True-Cool Max,AFE modified-W.D.RamAir,5"Hypermax exhaust,Hypermax DP,Firestone Ride-Rites,2.5" front leveling leafs,AutoMeter-ProComps/triple pillar,heated TTT mirrors,DEI remote start,Amsoil enhanced.
Rich D is offline
post #4 of 6 (permalink) Old 10-25-2012, 09:30 PM Thread Starter
Bulbs are fine, I wish it was that easy.
I've also been getting an airbag light during night driving which might be something else in the column. I'm not sure if these could be related and if I can fix both while I have the dash and column apart.
skydive is offline
post #5 of 6 (permalink) Old 10-26-2012, 12:41 AM
Rich D's Avatar
Do a search for internet search for superduty steering column short, there's a video/article or two out there showing a known wire rub(bare wire) issue. There also a video on changing the multi function switch.
Rich D is offline
post #6 of 6 (permalink) Old 10-27-2012, 11:13 AM
I'm having similar problem. I could not find the video. In my case, the headlights will not come on at night until I giggle the turn signal handle.
2005 F350 6.0 Super Crew
2005 Excursion 6.0
jed1894 is offline
