Turn-Signals and Back-up light Dead....Help! - Diesel Forum - TheDieselStop.com
Old 03-14-2010, 03:14 AM   #1 (permalink)
garryk6's Avatar
OK, I was changing my Tail Lights out to the new 08 style lights. Had the key on, and the truck in Reverse, and accidentally shorted the B/U light wires. Lost Back-up lights and Turn Signals. Checked fuses 17, 18 and 38. All good, checked good. Replaces with new, still same, power at fuse bluck, and fuse good, but no lights. Saw that trailer harnes might be a problem. Unplugged my connector housing from the harnes plug, found water in the plug. Dried it out, but still no lights. Any other ideas?? Is there another fuse, or circuit-breaker or relay that I missed? Brake lights all work and the 4 way flasher works too, but still no B/u or Sig....
Thanks in advance,
Garry in Alaska
Sorry... This is on my 2002 F350 4x4 CCSB, 5.4 6-spd....
2005 EX LTD 4x4 PSD, V's w/ Summit "gas" leveling kit and modified B's, Radius Rods, 30mm sway bar, Eagle 114 20's w/ 305-55-20" Open Country AT's, Prodigy, Dual-Cam HP hitch, all Black (Secret-Service-Edition)The Ex The Harley EX Road Armor Front Bumper with custom Aluminum winch-hole cover-plate.
2001 Nomad 308 (32" w/ 14' Slide) Bunkhouse
4 kids and love to travel and camp!
2001 F350 XLT 4x4 CCLB Dually 7.3 6spd 180k and still running strong!
2002 F350 XLT 4x4 CCSB SRW 5.4 V-8 6-Spd 17,811 original miles (Bought 2-5-10)
garryk6 is offline
Old 03-14-2010, 07:53 PM   #2 (permalink)
garryk6's Avatar
Well someone from the Ford Trucks Enthusiasts forum just told me to go check Fuse 27. It is not labeled as B/U or Turn SIg, but it was blown, and when I replaced it, everything works great!! Hope this helps someone else.
Garry in Alaska
garryk6 is offline
