Turn Signals Not Working? - Diesel Forum - TheDieselStop.com
post #1 of 11 (permalink) Old 03-29-2007, 05:44 PM Thread Starter
Out of the blue, my turn signals stopped working today. I checked the #18 fuse under the dash (in addition to all of the fuses) and it was fine. I also looked for one of those round metalic looking blinkers but couldn't find one. Any ideas?
My Daily Driver / Backup Tow Rig: 2013 F350 / Crew Cab / Short Bed / Diesel / Lariat Ultimate Package / Single Rear Wheels
My Daily Tow Rig: 2004 F350 / Crew Cab / Short Bed / Diesel / Lariat / Single Rear Wheels
Picture of my rig with my gooseneck dropping off a shipping container at a customer's house:
Allagash is offline
post #2 of 11 (permalink) Old 03-29-2007, 05:46 PM
FamilyRide's Avatar
Re: Turn Signals Not Working?
Just dead stopped?
Mine recently started acting funny on right turns. It'll hyper-blink but the lights aren't blinking, it just sounds like it. I have to put a little pressure on the wand towards neutral and it starts working right. It's annoying. Left works fine.
If it's dead and you've checked everything, can you find anything else that's dead or acting up?
2004 EB Excursion, 4x4, 6.0, Magnaflow Exhaust, Isspro Gauges in an under cubby pod, Fumoto, V code front springs, bubba lights and newly added so called bullet proofing, including PMax turbo.
FamilyRide is offline
post #3 of 11 (permalink) Old 03-29-2007, 08:46 PM
there is 2 fuses under the hood 20a that feed both sides. the flasher is under the dash toward the center above the accellerator pedal just below the radio. if you have a strong back you'll have to crawl under the dash to get to it. it has a black snap on cover on it & it is the blue relay. its an electronic solid state type.
certified ford dealer 7.3L,6.0L & 6.4L diesel tech & foreman
dvtech is offline
post #4 of 11 (permalink) Old 03-29-2007, 09:44 PM
The multifunction switch is going south. Have replaced two all ready, $100 for the unit.
05 F250 dark copper 4x4 cc King Ranch sb, 6.0 powerstroke, torqshift, tow command, moon roof, power sliding rear, adjustable pedles, camper package.
Diesel_junkey is offline
post #5 of 11 (permalink) Old 03-30-2007, 02:13 AM
Or it could be a blown bulb. If one goes out on one side, that side will flash rapidly or not at all. Happened on my F150 and my Exloder
2004 Ford F150 Super Crew
Vehicle Assembly Tech at
Ford Kentucky Truck Plant
HOME OF THE SUPER DUTY
fordKTPguy is offline
post #6 of 11 (permalink) Old 03-30-2007, 12:31 PM Thread Starter
They stopped working altogether. I had no choice but to use the truck this morning and I had to put my hazards on in a parking lot for a couple of minutes due to where I was parked. When I jumped back in, I took off and turned the hazards off. It was then that I realized that the hazards worked...so I tried the turn signals and they both worked again. Problem solved. But I'm not to confident that it won't happen again.
Allagash is offline
post #7 of 11 (permalink) Old 03-30-2007, 12:48 PM
Like I always say, "Only a Ford will fix itself"...LOL [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
Sorry to all the loyal 7.3 guys, but I traded my '91 7.3 in on a 2002 F250 Ex cab V10 4x4. SCT Xcalibrator2 with tunes by Powerplay Performance. 285/75/16 Toyo M/T's. Took a long time to get used to the ping-pop of a cooling catalytic converter...LOL.
'85 Bronco swapped up to a 302 4bbl from the 300 I6, NP435 4spd, NP208, 32x11.50x15 Radial RVT's, Soon to be 6.9 turbo powered.
86 F350 Cab&Chassis with a dump bed. 2wd 6.9 and 4 spd tranny. No mods to engine.
2000 Volvo 660 N14 Cummins, 500hp 1650 ft lbs, Autoshift tranny 10spd.
What part of "SHALL NOT INFRINGE" do you NOT understand?
aceohearts is offline
post #8 of 11 (permalink) Old 03-30-2007, 01:17 PM
Teebird's Avatar
Mine was doing this for a while. Happened to be the bulb filament hadn't completely broken away but had broken at one end and would intermittantly (sp) act up. Went away after replacing bulbs.
2003 F250 XLT 4x4 Sport Crew Cab,
Built May '03, Bright Red, 6.0 Auto, ESOF 4x4, 3.73LS, 4.5" Edge Lift, 315/75-16 BFG KO A/T's, Polished/Clear Powder Coated Diff Covers, Weld Cheyenne 8 Wheels, Line X, Overhead DVD, Torza Tonneau Cover, 30' Fleetwood Gearbox Travel Trailer
Teebird is offline
post #9 of 11 (permalink) Old 03-30-2007, 09:26 PM
Kind of surprised that no one said anything about checking the fluid...
2006 F-250 Lariat PSD Fx4 Shortbed Extended Cab, 4" MBRP Cat Back (have the DP just not installed yet), Fumoto Valve, Viper 160XVL Remote start
Engine born on date- 5/13/05 (a Friday no less)
brnscofrnld is offline
post #10 of 11 (permalink) Old 03-30-2007, 10:10 PM
Figured that was the first thing they'd do. [img]/ubbthreads/images/graemlins/rolleyes.gif[/img] After all, if they don't know enough to check the blinker fluid, they shouldn't be working on their own truck...TAKE IT TO THE SHOP!!!
post #11 of 11 (permalink) Old 07-13-2014, 07:43 PM
socaldesertdad
Guest
Posts: n/a
My Hazards worked but not the turn signals on my 04 Super Duty. It turned out to be fuse #27 (ignition switch run feed).
