Vacuum Canister - Diesel Forum - TheDieselStop.com
post #1 of 3 (permalink) Old 02-25-2013, 03:43 PM Thread Starter
Vacuum Canister
Has anyone heard of the vacuum canister going bad?
My heater is on defrost only which usually means a vacuum leak plus my pump doesn't shut off. If I unplug the pump from the canister and put my finger over the tubing the pump stops. When I plug the pump into the inlet side of the canister and cover the outlet of the canister with my finger it doesn't stop.
I put Warn hubs on so I don't use the vacuum for my four wheel drive. Could I bypass the solenoid and canister just for the heat control or do I need one or both of them?
Thanks for any input.
2002 F350 Crew Cab,4X4,Long Box,PSD
Royaldiesel is offline
post #2 of 3 (permalink) Old 02-26-2013, 08:12 AM
My Photos: (19)
Sounds like you found the problem. Haven't heard of that, but you tracked it down quite well.
DP-Tuner 80T, 160cc single shots, GTP38R turbo, Ceramic coated IH up-pipes, coolant filter, 6637, DIY exhaust brake, openair CCV, propane, SBC DD all ceramic clutch, ISSPRO EV boost/pyro/HPOP pres./rear end temp, 4" lift, traction bars, 255/70R22.5 tires, York air compressor, 16 flashy lights, 12 strobes, 12 switches on console, 9 switches on the dash, 7 two-way radios, 5 air horns, laptop, siren, 105 gal. in-bed fuel tank, Kennesaw Mountain front bumper
'86 H-D Sportster - 16" apes, custom paint, custom pipes to fishtails, single fire ignition, leather saddle bags on custom brackets, bagger fender, solo seat, home made luggage rack, all LED rear lights
BTBBT is offline
post #3 of 3 (permalink) Old 02-26-2013, 04:23 PM Thread Starter
Sort of
It was the vacuum solenoid
Glad I checked twice before buying a black lunch box for nothing
Once you lose the vacuum in that canister it takes a minute to build back up and I diidn't wait long enough before jumping to the conclusion that it was the canister
