Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > General Questions
General Questions General questions related to 1999-2007 Super Duty trucks. If it doesn't fit the other categories, post it here. Gas engine discussion that pertains to all models is allowed. Specific gas engine questions should use the Gas Engines forum.
Old 06-06-2007, 11:54 AM   #1 (permalink)
Vacuum front axle hub inner knuckle seal replacement clarification question
Do I need to pull the axle to replace this seal or does the axle remain in the housing and seal driven out and pressed in around it?
1994 IDI Turbo CC 4x4
PPrash is offline
Old 06-06-2007, 05:17 PM   #2 (permalink)
klhansen's Avatar
My Photos: (92)
Re: Vacuum front axle hub inner knuckle seal replacement clarification question
I suppose you could replace the seal with the axle in place, but you've gone far enough that it's just easier to deal with after you've pulled the axle out. Once the hub/bearing is off the knuckle, the axle comes out with a little persuasion with a pry bar. Having the axle out gives you a chance to check the u-joints more closely as well.
Actually, it would be next to impossible to replace the seal with the axle in place.
99.5 F250 PSD Supercab LB 4x4, 6spd, 3.73LS, Boost & pyro gauges, Swamps S175/146 injectors, Jody's 80 HP Econo PCM (classic version), AIS, coolant filter w/"hokum" bracket, regulated return, heated mirror mod, lighted cupholder, Marinco heater plug-in.
Hard or no-start? Check here
klhansen is offline
Old 06-06-2007, 05:54 PM   #3 (permalink)
does the new seal press onto the axle or into the kuckle housing? (It has to rotate on one of those two surfaces)
PPrash is offline
Old 06-06-2007, 10:56 PM   #4 (permalink)
There is a driver for installing that seal. It performs 2 steps... the first being driving the seal onto the axle until it bottoms out at the correct depth, then the same driver is used to drive the seal and axle into the spindle all at once.
alexb is offline
Old 06-06-2007, 11:10 PM   #5 (permalink)
So how do the folks who claim to change theirs at home get it done? With some sort of pipe? I can see putting the seal on the axle with a pipe or something but not sure I could see pushing the seal in the spindle correctly?
PPrash is offline
Old 06-06-2007, 11:28 PM   #6 (permalink)
klhansen's Avatar
My Photos: (92)
The seal is a TIGHT fit on the axle shaft, but fits a bit easier into the knuckle. The rotation takes place within the seal itself, the outside in contact with the knuckle being stationary.
You don't really NEED to install the seal/axle assembly in the knuckle with a driver, but the driver has a shoulder on it that sets the proper seal depth in the knuckle. Can't do that with the home-built pipe&flange tool. But, bolting the bearing hub on does a pretty good job of setting the depth, IMO.
klhansen is offline
Old 06-07-2007, 07:14 AM   #7 (permalink)
does that mean the seal acts as a guide/bearing?
early 99(6/98) f250 xlt 4x4,psd,xle4,auto,sc,lwb.
99.5 air box, scorpion spray in bedliner, isspro ev pre-turbo pyro,trans,and boost,a-pillar mount. rancho rsx shocks,
superchips microtuner(2 program), magnaflow 3.5" dp 4" back exhaust, zoodad mod,
31' jayco 5'er
goldrush is online now
