Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > General Questions
General Questions General questions related to 1999-2007 Super Duty trucks. If it doesn't fit the other categories, post it here. Gas engine discussion that pertains to all models is allowed. Specific gas engine questions should use the Gas Engines forum.
Old 08-23-2006, 01:25 PM   #1 (permalink)
Valve stems
My early '99 F250 has the factory aluminum 8 hole rims. I had one of the cheap rubber pull-through style valve stems split the other day causing the obvious flat tire. Even though the tire shop puts new ones in every new set of tires, this one failed after about 3 years. Every 3/4 ton truck I have owned in the past had brass stems that are held in place with a nut on the outside but I have never seen these used on a single wheel superduty. Has anyone tried to use these? Will they work with our factory Alcoa rims? Changing a tire because of a stinking valve stem in 100 degree weather ain't no fun and I would just as soon avoid it in the future. [img]/ubbthreads/images/graemlins/confused.gif[/img]
1)early 99 F250 crew cab XLT short bed 4x2 PSD 6 speed 3.73 LS AWA5 code JNB Gen.II reg return fuel system Motorcraft Severe Duty air intake system Banks exhaust and Big Head wastegate actuator Edge Evolution programmer ver.19 Autometer Z-series pyrometer pre-pump and tank mods harpooned tank factory AIC heater core shutoff valve block heater cord mod Optima red top batteries 2002 headlights w/ Sylvania Silverstars Bilstein shocks Michelin XPS tires Ranch Hand cab steps Ruenel rear bumper 249,000 and counting
2)89 F250 regular cab XLT 4x2 7.3IDI 5 speed 3.55 mostly stock 361,000 and still counting- sold Jan 2008
BETA is offline
Old 08-23-2006, 09:24 PM   #2 (permalink)
Re: Valve stems
I sent you a PM
"Real Trucks Don't Have Spark Plugs"
2000 F250 Lariat Crew Cab, Island Blue/ Harvest Gold , 7.3 PSD, LWB, 4x4 ESOF, Auto Trans. 3.73LS, 285/75/16,AT/BFG, Husky Liner Floor Mats, AIS/Foam Fender Sleeve Mod. Line-X, Leer 100XL Cap, MOOG Balljoints, Performance Friction Rotors and Z Rated Carbon Metallic Pads, Fumoto Valve, DIPricol Optix Gauges, Pyro,Trans,Boost, A-pillar Pod, MBRP 4 inch T-304 SS Cool Duals, EBPV delete 6.0L Trans. Cooler,Schaffer's Transmission Fluid, BTS Transmission, DP Tunes, Stock/High Idle/40T/60T/80E/120R/140SMK 309.77 hp/605.12tq
Spooling and Cooling by BWD with a Turbonetics Turbo & Spearco Big 6.0 IC
"The Smoke Don't Mean Its Broke!"
Bushwakd is offline
Old 08-24-2006, 01:44 AM   #3 (permalink)
Re: Valve stems
I've always had rubber stems. I had 2 go bad on me within 3 months once. I attributed it to wheel cleaner drying out the rubber, not to mention they were both on the side that sits in the sun most often when parked in the driveway.
Patrick
...A "Faceplant" is my most consistant wakeboarding "move"
'06 F-350 4X SRW LB Crew Lariat to pull an '04 Malibu VLX and a 10k dump trailer.
Make Welfare as hard to get as a Building Permit....
http://photos.thedieselstop.com/show...hp?photo=32801
Faceplant409 is offline
Old 08-24-2006, 03:56 PM   #4 (permalink)
Re: Valve stems
There are two class of rubber valve stems, under 80's psi and over, you need the over model. Rubber on the outside but steel shaft on inside. specify them when you get your tires done.
99.5PSD F350 3/99 CC XLT Auto 4X4OffRoad NO-ESOF 4WABS PTO/AIC Sterling BrushGuard W/front RecTube, Reading Low Profile Utilbody, 3.73LS SRW LWB Trailer & Camper, Oilguard bypass,Permacool 6pass Fan Aux trans cooler&filter, crankcase vent,Hutch Tank mods,8120#GVW empty
CKing is offline
Old 08-26-2006, 09:38 AM   #5 (permalink)
Re: Valve stems
So that is why some are all rubber and some are rubber base with brass stem. I still would really prefer all metal stems. I do appreciate that tidbit of info.
BETA is offline
Old 08-26-2006, 10:36 PM   #6 (permalink)
Re: Valve stems
I have all metal stems. All brass with a nut. Just ask for them. Have them on my dually and my srw.
2007 F350 4Dr Diesel Dually Lariat, auto, 4x4, 4.10 ls., snow plow prep, loaded.
2001 7.3 - gone
1995 7.3 - gone
4drdually is offline
