VSM interchange from 02 SD to Excursion? - Diesel Forum - TheDieselStop.com
Old 07-08-2006, 12:23 PM   #1 (permalink)
I have two 2002 trucks. An Excursion and F-350. Both have VSM symtoms. (door ajar light, no power locks, etc) I am wondering if anyone knows if the same VSM module is used in them?
2002 F350 4x4
PPrash is offline
Old 07-08-2006, 06:44 PM   #2 (permalink)
Re: VSM interchange from 02 SD to Excursion?
IIRC, there are some pins missing in the F250/350SD VSM, and the programming in the VSM's are vehicle dependant. The programming must be pulled & saved from the old VSM before replacement, and programmed to the new one, or they can program to factory build using the VIN.
Buddy
Former Ford Diesel Tech
ASE Certified Parts Counterperson, Automotive, Medium, & Heavy Truck Technician
1999 F250 XLT 4x4, Red, 7.3 6spd AWA5, 3.73LS rear, CCV Mod, APC Headlamps, Autometer C2 Gauges, (Boost,Pyro,Trans), 4" Turbo-back exhaust, XM Radio, AIS, ITP Regulated return, fuel feed lines, Airdog, & 4pos. chip.
My Truck
2001 Ford Escort ZX2 - Black- 4cyl 2.0DOHC, 5spd.
1999 F350 4x4 XLT, CC/LB PSD, 6spd, Aluminum service bed, York Compressor Onboard air, CCV, Custom Intake & Exhaust, Strobes and a few other goodies
RIP Steph F. & Trista J., 4/27/07, you will be missed by many.
budman451 is offline
