Water Leak Into Cab and Fuse Box 2006 - Diesel Forum - TheDieselStop.com
post #1 of 6 (permalink) Old 12-19-2007, 12:46 PM Thread Starter
For the past two rains and one car wash my '06 F-250 6.0 gets about a cup of water on the driver's side floor, and the fuse box gets wet, and lots of lights, the radio, and the "Check Guages" displays dimly and on and off...Truck starts and runs fine. It dries up and all works fine. Door gasket is dry, entire engine compartment is dry. I'm thinking water is coming through the vent in front of the driver side windshield and leaking through the firewall? Haven't looked hard up under the dash yet...I've owned the truck since new 10/06. Just started doing this about 3 weeks ago...Any ideas?
Marc
mbuonaguidi is offline
post #2 of 6 (permalink) Old 12-19-2007, 01:17 PM
whitjo's Avatar
Re: Water Leak Into Cab and Fuse Box 2006
Not sure about the '06 but it seems like I saw somewhere a post regarding a leak near the DS "A" pillar?
Early '99 F250 SD, 4X4, SuperCab, Long Bed, 7.3L "PowerStroke" Diesel, Auto, PMT1 PCM w/DPTuner 80 tow, 190K miles,
Volant intake, ISSPRO gauges, BDS front leveling kit, 4" straight piped, Dick Cepek 18x9 DC1-Chrome, Nitto Terra Grappler 325/65R18,
Pro GOD, Pro Guns, Pro Life Important Notice, Pro Life changes when someone breaks in.
whitjo is offline
post #3 of 6 (permalink) Old 12-19-2007, 01:36 PM
OneTonHillBilly's Avatar
Had the same thing, dealer just found a bad cab light. Looked fine but that's was it. There was also a post on ehere, I have the sunroof and the drain holes plug up but not an issue from my end. Just a thought, PULL THE FUSE PANEL COVER UNTIL FIXED, I did. The water doesn't get into the panel without the cover attached.
OneTonHillBilly is offline
post #4 of 6 (permalink) Old 12-19-2007, 02:05 PM
Check the fire wall. There should be a couple of plugs there where the clutch pedal would be. If you have anything after market that uses these make sure they are caulked. You might need to pull the fuse box off to check. I believe there are 4 8mm bolts that hold it on.
2005 F350 6.0 PSD srw lb sc Zf6 speed
mods: BD exhaust brake- Dura flap mud flaps-Piaa back up lights-Wilson cell amp and antenna-Midwest short throw shifter--C-Betr mirrors-Burning B100
wdwkr is offline
post #5 of 6 (permalink) Old 12-19-2007, 05:35 PM Thread Starter
Sweet...! I think you got it. I'll looking into the cab light and check the firewall too. It got stolen, taken to Mexico for 2500miles, then recovered. Maybe the bad guys yanked some alarm wires that go through the firewall. I suspect it's the light though...not Gremlins after all. Love that truck...!
Marc
post #6 of 6 (permalink) Old 12-20-2007, 12:34 PM
mine leaked right after a windshield replacement..
yours sounds different though...but if all else fails check the gaskets etc...
early 99 f350 4x4 crew cab
work in progress
southmike is offline
