Weird door ajar problem - Page 4 - Diesel Forum - TheDieselStop.com
Old 04-12-2008, 05:09 PM   #46 (permalink)
My Photos: (5)
Can someone post a pic exactly where the switch is? (and where to spray the lube?) - I looked given the description on my 99 CC but can't see any switch that might be sticking.
'99 F250 PSD CC AUTO, Lariat, 565,000 km's, Raider cap, K&N air filter, spray in liner, stainless grill inserts, and command start for those -40 mornings, no more running out in my briefs to fire her up!
my priceless pic! & CPS removal and HPOP O-ring Howto pics!
Glenstr is offline
Old 04-28-2008, 05:40 PM   #47 (permalink)
I fixed mine
Thanks for the WD-40 idea.
I used it on my Edge this weekend and fix the stupid dinger and door ajar light.
Beats the heck out of slamming the door to try and fix it.
Spray the door latch on the inside of the door. Just hose it down.
Please be aware that WD-40 is a solvent not a lub, so it my flush out the necessary lub.
2003, F250, Super Duty, Super Cab, 7.3, Auto, 4X4 Silver, 2" lift in front only, 46 gal fuel tank, Billet Grill, 285X75X16 BFG MT, Bilsteins, Firestone Air Rear, B&W Gooseneck, We call it the "Silver Knocker"
reba is offline
Old 04-28-2008, 07:50 PM   #48 (permalink)
I just bought a '99.5 F350 CC SRW Lariat 6speed w/ 119k, and it has this problem. I WD-40'd it earlier today up at the shop, problem went away for a few hours, now it's back again....
VSM? Vehicle security module? I would think if this is the problem, it wouldn't have gone away for a few hours when I sprayed down the switches...?
Anymore insight?
kerickson73 is offline
Old 07-02-2008, 08:33 PM   #49 (permalink)
Delwars's Avatar
My Photos: (5)
Anyone know how to disable it???
2007 F-350
Lariat
4X4
CC/LB
Firestone Ride-Rite's
Coolant Filter
Edge Insight
Fuel Pressure Gauge
SCT Tuned by Matt@ Gearhead
Delwars is offline
Old 07-25-2008, 07:01 PM   #50 (permalink)
have not been on this site in awhile. Thanks for the info. I just started having the same problem
2003 FORD EXCURSION 7.3L TURBO DIESEL, Superchip,Edge Atittude with Juice, True Flow intake, Walker BTM, Prodigy Brake Control, 30 MM Hellwig Swaybar, Timbrens, Bilstein Shocks.
Alpine CD Player (65 watts x 4),6 disc Changer, Sony and factory Entertainment System,2 DVD players, JL Audio 10" console Sub. 10" HE2 Fosgate Sub in a Versatech Box.
2-Punch 500's. 1-Punch 250. 6-Alpine 3 way Door Speakers.
XM Radio. One bad ass system if you like it loud!!! ( not for rap Music/ ROCK ONLY )
Viper Alarm on EX and Trailer with Transmitter.!!!
62873 is offline
Old 07-28-2008, 11:52 AM   #51 (permalink)
how do you determine which door latch.
my excursion has 8 latches total. I have sprayed, sprayed, prayed, and strayed some more.
The dealership is the last place I want to take my X.
any sugestions.
62873 is offline
Old 07-29-2008, 02:32 PM   #52 (permalink)
not very happy.
I tried all the WD-40 and contact cleaner tricks and no luck so I sucked it up and took it to my dealer today.
They said I need a new VSM!!!! $400.00 freaking $$$$$$$
I could live with out but. I pull a trailer and leave the truck running when loading so We have cargo lights and without the doors being about to lock by the key pad I and crap out of luck.
62873 is offline
Old 07-29-2008, 03:22 PM   #53 (permalink)
Delwars's Avatar
My Photos: (5)
Sooooooooooooooooooooooooooooooooooooooooooooooooo ooooooooooooooooooooooooooooooooooo anyone know how to TOTALLY DISABLE the door ajar?????????????????????????????
2007 F-350
Lariat
4X4
CC/LB
Coolant Filter
Edge Insight
Fuel Pressure Gauge
Delwars is offline
Old 08-13-2008, 10:31 AM   #54 (permalink)
Just remove the relay in the fuse box... When I bought my 99 crew I noticed the dome light did not work so I replaced the bulbs, still nothing, checked fuse, nothing found relay missing, replaced relay, the light stayed on and did not turn off, tried wd40 no luck. The passenger door does not fully latch so I think that is the problem. So for now the relay is still out.
99.5 F350 crew cab, 7.3 PSD Weld Shop on Wheels
jeepnjay is offline
Old 11-15-2008, 08:45 PM   #55 (permalink)
here is a view of your truck. Without a scanner one can tell which door it is. even with that the 2 rear doors are on the same circuit.
in pic 2 these are the switches in each door latch. note: door panel must be removed..
83 F250 6.9 4 speed
04 F350 6.0l Crew cab,Sunroof,Leather,Heated seats,8ft bed,reflex liner,5th wheel hitch and gooseneck.. Bone stock.
My site motoxfarms.com
born2ride is offline
Old 11-15-2008, 08:47 PM   #56 (permalink)
forgot to hit upload.. LOL
83 F250 6.9 4 speed
Old 12-26-2008, 04:06 PM   #57 (permalink)
Opposite of the Norm
I have a similiar, but opposite problem. I first noticed that my dome light was not coming on when I opened the door. Then I noticed that I was able to still operate the power windows once the keys were removed and the driver's door was opened. So I figure that the truck does not know that the door has been opened. It is a 2001 F250. Could this problem be with the same switch at the latch?
BTW, it started after I installed aftermarket door lock actuators. I clipped the wires going to the original actuator. Is this the same wire for the switch, or is it separate?
rutwad is offline
Old 12-27-2008, 08:22 PM   #58 (permalink)
Sound like the door switch is not working did you leave it unplugged? No the wiring is different for the actuators.
83 F250 6.9 4 speed
Old 12-27-2008, 08:49 PM   #59 (permalink)
I must have unplugged it. Should be an easy fix. Thanks.
rutwad is offline
Old 01-09-2009, 11:08 PM   #60 (permalink)
thats awesome i wasnt even looking for this answer and i found it... I love you guys
Y2K,PSD,Crew Cab,SWB,4x4,diy tymar intake,jenson indash dvd,nav,2 12" kenwood subs,4" silverline turbo back exaust,285/75/16 shoes,
climber417 is offline
