Re: Welding to the frame?
The only other thing that Ford does warn you about is not drilling or welding within 3 inches of a spring perch or a riveted cross member. Why weld the traction bar on? I would bolt it myself that way if you must move or remove it is much easier. I have been welding on the ford frames for 7 years.... Never had a problem with cracking or flexing... so weld if you must, but bolting is good too if you might ever need to repair anything. Just a thought.
2000 F350 Dual, Crew cab, 8ft bed, "The great white beast", Banks modified Garret turbo, Banks Exhaust, 3.73, 4WD, Super chips, Bullydog Trans shift pack, Auto meter gauges, 6.0 tranny cooler, Zoodad mod, SP EBPV/Trans controller, CCV mod coming soon, Foil delete, DIY Tymar and funky running boards.
