What does the block heater heat ?coolant or motor oil - Diesel Forum - TheDieselStop.com
Old 11-04-2009, 07:56 AM   #1 (permalink)
I'd like to know what the block heater heats up. In case it heats up the fluids is there a kind of circular pump in? sorry perhaps stupids questions but I'm a brandnew owner of an 01 F350 and feel pretty lost almost alone her in good old Germany
Heinz- Jürgen Kowalek is offline
Old 11-04-2009, 08:04 AM   #2 (permalink)
Mark Kovalsky's Avatar
Guten Tag!
The block heater warms the coolant.
Mark
Mark Kovalsky is online now
Old 11-04-2009, 09:10 AM   #3 (permalink)
SmokeyWren's Avatar
My Photos: (44)
The so-called block heater is not in the block. Instead, it's in the base of the oil filter and the engine oil cooler. There are both oil and coolant passages in that base, and the heating element is in a coolant passage. So it directly heats the coolant, but some of the heat also transfers over to the oil passages.
It doesn't need a pump. Convection will cause warm coolant to flow away from the heating element and be replaced by cooler fluid, so there is some flow in the coolant passages of the engine. The motor oil will also flow some, but the main reason for the block heater is to warm the coolant, and thus also warm the metal in the engine block and heads.
SmokeyWren is offline
Old 11-08-2009, 05:55 AM   #4 (permalink)
Thank you very much ,
your reply was very helpful because I think about to install an vegatable diesel unit.
Old 11-08-2009, 05:59 AM   #5 (permalink)
thanks for your answer
I did'nt expect any german words.
