what does an F450 weigh?????? - Diesel Forum - TheDieselStop.com
post #1 of 6 (permalink) Old 09-13-2005, 04:02 PM Thread Starter
I got my truck on a scale and crapped my pants 11,400 empty. I have a heavy steel bed and full PTO hydraulic hoist. I am contemplating removal of the bed and hoist and putting on an aluminum bed. an aluminum bed weighs about 900 lbs I need the weight of the Cab & chassis so I can figure the weight of my hoist and bed.
99.5 F450 60" CA crew cab 4x4 6 speed
Thanks in advance
WFTREE
NEVER FORGET, NEVER RELENT, NEVER DISPARAGE 09-11-01
1999.5 F450 CC 4x4: 315 RWHP 710 TQ 6 speed with BD short shifter; 60"CA; South Bend clutch; Ported BB turbo; Spearco 6.0 charge air cooler; pop off valve; dieselsite I/C boots; 203 degree thermostat; pillar mounted pyro, boost coolant temp guages; engine mounted fuel pressure; HX hose; shimmed regulator; Tymar intake; zoodad; Banks brake; 4" DP to 4" exhaust to Aeroturbine muffler to 4" chrome stack; diesel power flip chip, 85 gallon aux fuel; Dahl 100 heated fuel filter; in tank mod, Hella FF driving & fog lights,
WFTREE is offline
post #2 of 6 (permalink) Old 09-13-2005, 07:55 PM
SmokeyWren's Avatar
My Photos: (45)
Re: what does an F450 weigh??????
Ford estimates the '99-'03 F-450 7.3L PSD CrewCab 4x4 PSD with a 1,000-pound bed and 60" CA to be 26,000 GCWR minus 17,200 tow rating = 8,800 pounds. But we know their tow rating is overstated by a few hundred pounds because it doesn't include options such as AC, cruise control, etc. And no tools, cooler, passenger, or anything else.
I usually consider the minimum weight of a '99 F-450 with an aluminum tow body when wet and loaded for the road, including driver and one passenger, a cooler and a few tools, to be about 10,000 pounds. That makes a realistic tow rating of about 16,000 pounds max.
The PTO and dump cylinder are heavy suckers, and your steel bed must be really heavy to push you up over 11,000 pounds. [img]/ubbthreads/images/graemlins/shocked.gif[/img]
SmokeyWren is offline
post #3 of 6 (permalink) Old 09-13-2005, 11:02 PM
If you shovel the crap out of your pants, you could get it down to 11,200. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Ron
aussiekeeper is offline
post #4 of 6 (permalink) Old 09-14-2005, 05:47 PM
I have a B&W bed, and my truck weighs 10,200lbs. full of fuel( 70gals.) minus my lard butt in the truck.
Hitchhiker: "99" F450w/6sp, 4wd, cc,Garret BB turbo,AIS air filter,203 stat,Evans coolant,CCV reroute, GV over & under, B&W bed w/fiver hitch, 4" exhaust, Pac brake, Link Air ride suspension, Transfer flo, pyro & boost, Amsoil.
Bruce Williamson is offline
post #5 of 6 (permalink) Old 09-14-2005, 11:16 PM
Mine must be a lightweight - 172" wheelbase, CC, PSD, 2WD, with a custom built Pacific Truck Bodies steel utility bed tips the scales at 8500 lbs.
Alan Hepburn - F450 CC PSD 2WD 4R100 XLT+ RAM KILLER
Proud to be a Blue Star Family...Support our troops by supporting their mission.
Alan_Hepburn is offline
post #6 of 6 (permalink) Old 09-14-2005, 11:47 PM
My 2000 regular cab 450 had the shipping weight listed as 6240#, once upfitted with a tow truck body & full 19 gal. fuel (without driver) it weighed 9600# My 05 S/C F450 (with the same type bed)weighs 11,000 empty with 50 gal fuel, and no driver. The bare 05 S/C 2wd F450 cab chassis (with factory tank & 19 gal fuel) should weigh about 7000# Ford's tow ratings assume about 900-1000# body weight, but I don't remember which. LS
LSchicago2 is offline
