What Paint for Toolbox? - Diesel Forum - TheDieselStop.com
Old 12-07-2008, 03:14 PM   #1 (permalink)
I have a toolbox in my truck bed and I think it is polished aluminum diamond plate. I want to paint it glossy black. In its current condition it weathered. What paint/primer should I use and what type of prep should I give it?
http://good-times.webshots.com/album/556506109PurdXz
99.5 ext.cab,8ft.Bed,6spd,DP Tuner(H.I.,80e,80t,120r)AFEstage2,Zoodad,Procomp (black rims) w/285/70/16DunlopA/T, ATS Housing, CCV, AIH, Autometer 3 guage cluster, MBRP T304, Stars and Stripes rear window tint,Outside P.A. system w/ice cream truck music or police siren depending on who is stopped in front of me. 1st time diesel owner as of 9/15/06
pezrock77 is offline
Old 12-07-2008, 03:40 PM   #2 (permalink)
chuckster57's Avatar
The best case would be to sand blast or bead blast to remove all rust and wearthering. Not being able to do that, if you use a good degreaser (superKleen by Castrol) or similar you should be able to get all the oils out of the surface. Diamond plate is a PITA to "sand". You can use a good steel wool, just start with say "0" depending on how rough the surface is and work your way up to "0000". If your using rattle can primer then I would use a good red oxide to help with rust prevention. Access to spray gun..I would use a good epoxy based primer. As far as color, I would think a "ceramic" engine paint would hold up the best. I have sprayed parts and then waited about 15 minutes and gone back with a heat gun to speed the cure. Only thing with ceramic paint is it takes 5 days to fully cure.
1997 Jayco 323RKS fifth wheel w/2 slides, Air Lift 5000 bags
Train Horns: Pictures here
PM please not visitor message
chuckster57 is online now
Old 12-07-2008, 04:46 PM   #3 (permalink)
thanks for your help. looks like this project may have to wait for spring.
