Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > General Questions
General Questions General questions related to 1999-2007 Super Duty trucks. If it doesn't fit the other categories, post it here. Gas engine discussion that pertains to all models is allowed. Specific gas engine questions should use the Gas Engines forum.
Old 10-11-2007, 02:27 PM   #1 (permalink)
What is the real difference between a F250 & F350
Between an F250 and F350 SRW, I have read that the only difference an additonal leaf spring in the rear. Can someone tell be if this is true?
segel10 is offline
Old 10-11-2007, 02:47 PM   #2 (permalink)
Re: What is the real difference between a F250 & F350
I think up to 2004, the only difference between a 250 and a SRW 350 was the spacer blocks, at least that is what I found out doing a bit of research. For the 2005 year and on, I have read that there are a number of differences now, including differentials internals and spring rates.
2008 F-450 Lariat Dark Stone Metallic over Pueblo Gold 4x4(manual shift transfer case, manual hubs), High capacity tow 4:88s, Off Road, Camper packages, Sirius Sat, Upfitter switches, DVD entertainment, tailgate step, traction control, Audiophile 6-disc, PTC Supplemental heat and heated seats(warm buns), rear sensors, traction control, tailgate step. Built May 8, delivered May 24
Reese Signature Series 24k fiver hitch, I installed it myself, best hitch I have found yet
Line-X bedliner, heavy duty floor mats
2003 Sunline F281SR(weekend getaways)
SeaRay 215EC
http://community.webshots.com/user/C...host=community
CaptSkup is offline
Old 10-11-2007, 03:24 PM   #3 (permalink)
SmokeyWren's Avatar
My Photos: (33)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Segel10</div><div class="ubbcode-body"> Can someone tell be if this is true? </div></div>
Not true since the 2005 models came out. It was close to true for some months during '99-'04 model years. But for 2008, the differences other than the rear spacer blocks in 4x4s include:
<ul>[*] Rear springs are heavier on F-350 SRW unless the F-250 has an option that includes overload springs.[*] Rear axle is heavier-duty on F-350 SRW.[*] 17" standard tires and wheels on some F-250s, so pay attention if looking at trucks in stock - especially with XLT or XL trim.[/list]
SmokeyWren is offline
Old 10-11-2007, 04:03 PM   #4 (permalink)
loft306's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: SmokeyWren</div><div class="ubbcode-body">[*] Rear axle is heavier-duty on F-350 SRW.</div></div>
Mostly true, the axle is the same model but has the larger axle shafts on the inside.
~ Mike
2008 BLACK F350 XLT RC SRW 4x4, 6.4, Auto,3.73ls, ManualTransferCase,PTC-Heater. Pic's She is Sweet...
DORA recieved:9/14/07 || ReceiptDate:9/14/07 || SerializeDate:11/01/07 || SegmentDate:11/01/07 || SequenceDate:11/10/07 || BlendDate:11/13/2007 || GesitmatedBuildWeek: 12/10 || ProducedDate:11/21/07 || GateRelease:11/21/07 || ShipDate:11/24/07 || ArrivalDate:11/30/07 || SoldDate:11/30/07 ||
1992 F150 | 1987 E250 | 1983 CutlassCiera | 1979.5 K5 blazer
loft306 is offline
Old 10-11-2007, 04:46 PM   #5 (permalink)
Smokey, are the spacerblocks on the 350 "taller" than the 250?
2008 SD 250 PSD King Ranch 4X4, SWB, CC, Auto 3.73
Viper 791 XV alarm with remote start. FS2500 bypass filter. Edge Insight multi gauge. Line-X. Retrax.
Sequoia is offline
Old 10-11-2007, 05:21 PM   #6 (permalink)
7.3L F-250's Avatar
My Photos: (16)
Send a message via AIM to 7.3L F-250
also the new F350 has a heavier-duty front axle
-Tj
RIDES
1987 ford F-350 xlt lariat, full leather interior, 7.3L idi, banks turbo, E4OD, MBRP muffler, 6" lift, 38" superswampers for summer, 35" BFG all terrain for winter, bronze pearl paint
CURRENT PROJECTS
1979 ford F-350 custom 351m C6
soon to get a 7.3idi, ats non-waistgated turbo, 6" lift kit, Saphire blue paint, and much more
WANTS A
2008 ford F-250 XLT with a 6.4L and a zf-6
7.3L F-250 is offline
Old 10-11-2007, 05:59 PM   #7 (permalink)
whitjo's Avatar
Didn't the F350 also have a Dana 60 front rather than a Dana 50?
Early '99 (12/98) F250 SuperDuty, 4X4, manual hubs/TCase, SuperCab, LB, 7.3L "PowerStroke" Diesel, Auto, currently running PMT3, 158K
Volant cold air intake, ITP regulated return(on hold), Edge EVO, ISSPRO under-dash gauges, BDS front leveling kit,
Michelin LTX 285/75/16, new 600watt amp/speakers/12"sub, 4" straight piped, B&W GN hitch, AE scanner on board always!
My Truck
http://www.putfile.com/devdwt/images/121998
Other Toys:
2006 Z06 Corvette
1990 Jeep Rock Crawler
1999 Jeep Wrangler
2007 Harley FXSTC
"If a little bit is GOOD, a whole lot is BETTER, then too much barely is ENOUGH"
whitjo is offline
Old 10-11-2007, 07:00 PM   #8 (permalink)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: whitjo</div><div class="ubbcode-body">Didn't the F350 also have a Dana 60 front rather than a Dana 50? </div></div>
No
2000 F-250 Ex-Cab Shorty - 4x4 - 7.3l - Auto - CAT ELC - 203* - Dieselsite Coolant Filter - AIH Delete - ITP HPX - Bilsteins - Walker BTM - Ford Severe AIS - CCV Canister - SCMT 1700 - Harpooned Tank w/ ITP Pre-Pump Kit - 312k
My truck pics
Check out my 1964 Toyota FJ40 Build
tjsulli790 is offline
Old 10-11-2007, 07:31 PM   #9 (permalink)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Segel10</div><div class="ubbcode-body">Between an F250 and F350 SRW, I have read that the only difference an additonal leaf spring in the rear. Can someone tell be if this is true? </div></div>
F350
- F250
F100
Oneof6 is offline
Old 10-11-2007, 08:10 PM   #10 (permalink)
7.3L F-250's Avatar
My Photos: (16)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Oneof6</div><div class="ubbcode-body">
F350
- F250
F100 </div></div>
??? what the last time i checked the F100 changed names over to the ranger but im not positive
-Tj
RIDES
CURRENT PROJECTS
WANTS A
Old 10-11-2007, 08:11 PM   #11 (permalink)
For quite some time now all SuperDutys have come with Dana 60 front axles, from 250 on up to 550. 450 and 550 have wider track Dana 60s. I think Dana 50 were dropped quite a while ago.
SeaRay 215EC
CaptSkup is offline
Old 10-11-2007, 09:57 PM   #12 (permalink)
SmokeyWren's Avatar
My Photos: (33)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Sequoia</div><div class="ubbcode-body">Smokey, are the spacerblocks on the 350 "taller" than the 250? </div></div>
On 4x4s, Yes. Since '99-5 models, F-250 and F-350 DRW 4x4s have had 2" spacer blocks in the rear suspension. F-350 SRW 4x4s have had 4" spacers
Old 10-11-2007, 10:01 PM   #13 (permalink)
SmokeyWren's Avatar
My Photos: (33)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: 73_F250</div><div class="ubbcode-body">also the new F350 has a heavier-duty front axle </div></div>
Ummmmmmmmmm, no. F-250 4x4 and F-350 SRW 4x4 PSDs have the same Dana 60 front axle with 9.75" ring gear. F-350 DRW is a different animal, but this thread is only about SRWs. [img]/forums/images/%%GRAEMLIN_URL%%/wink.gif[/img]
Old 10-11-2007, 11:21 PM   #14 (permalink)
99-01 SRW truck came with a Dana 50 front. In 2002+ all models came with the Dana 60.
2004 F-350 Reg-Cab XLT, 4X4, SRW, 6.0 PSD, 6 speed, manual transfer case, Dark Shadow Grey, 285/75R16 Cepeck FC-II's on 16X8 Centerline wheels. built 3/23/04, 60k miles on the clock.
http://www.cardomain.com/id/canyonero02
Canyonero02 is offline
Old 10-15-2007, 03:16 PM   #15 (permalink)
doczenith1's Avatar
My Photos: (11)
F350
- F250
F100 </div></div>
Close but not quite correct.
F350-F250 would equal 100. [img]/forums/images/%%GRAEMLIN_URL%%/grin.gif[/img]
2002 F250SD Lariat, V10, 4x4, auto, 3.73LS, SC/SB, camper & off-road pkg. - added Silver Stars and SUVLights Harness, Pioneer Premier FH-P800BT deck, PRS-X220 amp and TS-W1240C sub, Pioneer GEX-P910XM XM Satellite Tuner, K&N FIPK, FM50 Delta Flow, ART Rotors, Performance Friction Pads, 285/75R16 Bridgestone Dueler A/T REVO's. - 12/01
2003 Mustang Cobra, black convertible. - 6/07
doczenith1 is offline
