What size new battery do I need? - Diesel Forum - TheDieselStop.com
post #1 of 9 (permalink) Old 07-20-2006, 09:34 AM Thread Starter
The passenger side battery on my '02 with 49k went out this morning. It was starting to get weak over the last few days and this morning I had to jump it with my wifes car to get to work...It has the original Motorcraft with 750 CCA's. Do I have to go back with 750cca? The reason I ask is Sears has a Diehard with 700cca in the 65 battery group that I like, thanks for any replies.
2002 Crew Cab Lariat Short Bed 7.3l
Superchip 1705
Walker BTM , Ford AIS w \ Zoodad
9" LCD DVD Player , Wood Grain Dash Kit
knsh913 is offline
post #2 of 9 (permalink) Old 07-20-2006, 09:41 AM
haul_n_horses2's Avatar
My Photos: (17)
Re: What size new battery do I need?
Motorcraft Group 65 has 850 CCA IIRC. You will need to replace both batteries at the same time. Lots of folks replace OEM with Motorcraft due to ready availability and long warranty. Similar batteries can be found at Walmart for $59. I went with Optima commercial Yellow tops but it requires modification of the battery trays, air intake etc.
2002 F350 Lariat CC 4x4 Auto 4.10 DRW, DP-Tuner F5 live tuned stock, quiet, 40dd, 40, 60, 80 tow, 80e and 120r, B&W GN, BrakeSmart, 'pooned tank, tank and pre-pump mods, 2 Dahl 100 filter, regulated return, BTS dual HPOP, AC singles with EDM 34 lpm nozzles, AIS, H2e, Spearco 6.0 IC, Hypermax 3.5" dp--> MBRP 4" 304SS exhaust, BTS tranny, 203 T-stat, Chevron ELC, coolant filter, Oilguard bypass with Schaeffer 9000, WranglerNW 200 amp alternator & Optima group 31 batteries, Nippon-Denso starter, SPA gauges, SteveRacer mods, Hella 80/100W 9007s, Hella Micro DE foglights, 1000FF driving lights, 220W backup lights, Stancor contactor, Michelin XPS Traction tires, X-Springs, Bilstein shox, custom bumpers but otherwise stock. Nov 30 '99 build engine with 16 K miles, Fluidampr, Comp Cam 910 springs, Melling LPOP and ARP headstuds.
haul_n_horses2 is offline
post #3 of 9 (permalink) Old 07-20-2006, 07:52 PM
I would replace them both since they are 4 years old, but if you replace only 1 they MUST be the same amps. If not the higher amp battery will boil the lesser battery.
Joe
2002 F350, Crew Cab, 4WD, ISSOPRO Gauges,
3.73, Auto, 2wd low range mod, No door dinger,
Interior lights off switch, Zoodad Mod,
Extra Trans Cooler, Before coolers trans fltr,
Coolant fltr, Crimestopper remote start/alarm
Oil Guard Bypass, Air horns
MOUNTAINMAN444 is offline
post #4 of 9 (permalink) Old 07-20-2006, 10:30 PM
Always replace batteries by the pair and get the highest cca you can find. I wouldn't mess with anything below OEM.
99 PS XLT 3.73 SC Auto Shorty, WD chip, triple A-pillar gauges
Ernest is offline
post #5 of 9 (permalink) Old 07-21-2006, 04:19 PM Thread Starter
Thanks for all you replies, I went back with the Motorcraft 750 cca, same as what was in there. If the factory installed batteries lasted 4 years, I'll give another set a try, I did replace both, makes a big difference when starting....
Superchip 1705
knsh913 is offline
post #6 of 9 (permalink) Old 07-21-2006, 07:49 PM
Diehard isn't what it use to be, so don't get stuck on them. I would buy the Motorcraft first. AutoZone Duralast was rating number one by consumer reports. That surprised me but I have never tried one.
You want the highest COLD Cracking Amp battery that will fit in the battery tray.
The more reserve you have, the less drain on the battery when starting, less drain on the battery = less stress on the alternator to recharge the bigger battery, that used less of its reserve, so it takes less to recharge.
Wayne B
2000 F-250 XLT PSD 4X4 ESOF Auto, SC, LB, Gauges, Mag-HyTech Trans Pan & Rear End Cover, <font color="red"> (((XM))) Inside</font>, ATV Racks w/ Two Kawasaki Prairie 400 4X4's sitting on them, 25' Rockwood TT. Ashburn, Va. Member # 103
Wayne B is offline
post #7 of 9 (permalink) Old 06-28-2007, 02:23 AM
So the $189 Die Hard Platinum is probably just throwing money down the drain?
'01 F350 CC SB SRW, 203 tstat, coolant filter,<font color="red">FTVB</font>, <font color="red">Ford AIS</font>, Amsoil so far, and a box of junk to install later.
In the hopper: chip, exhaust, WW, guages.
mrcpu is offline
post #8 of 9 (permalink) Old 06-28-2007, 08:39 AM
FTG-05's Avatar
My Photos: (25)
Wayne B
Never heard of that battery measure before...
[img]/ubbthreads/images/graemlins/grin.gif[/img]
'06 F-350 SRW 6.0 PSD
FTG-05 is offline
post #9 of 9 (permalink) Old 06-28-2007, 10:15 AM
JimTJr's Avatar
My Photos: (20)
You need the "series 65" Battery. I had the "Motorcaft MAXs" in my 99. Got them at O'Rileys auto parts. I think they were awesome, 109 month warranty, and 4 yr FREE replacement I THINK,, It was better than any other warranty I ever saw in batts before.
Jim T.*48* SLAPS Co-Founder, 30.8 yrs RETIRED UAW 6/01/06, Now an ART (Specialists Flight Chief) with the USAFR 414th MXS Seymour Johnson AFB.
New truck, 2011 F-350 SRW LB CC. White Platinum Lariat! 4x4
JimTJr is offline
