What is the torque specs for the lug nuts? - Diesel Forum - TheDieselStop.com
post #1 of 13 (permalink) Old 07-19-2006, 07:47 AM Thread Starter
T.I.A.
If you can read this, thank a teacher, THANK A VET. it's in English: 04/04 F350 Sold.
SAVAGESAM is offline
post #2 of 13 (permalink) Old 07-19-2006, 07:51 AM
haul_n_horses2's Avatar
My Photos: (17)
Re: What is the torque specs for the lug nuts?
165 ft lbs.
2002 F350 Lariat CC 4x4 Auto 4.10 DRW, DP-Tuner F5 live tuned stock, quiet, 40dd, 40, 60, 80 tow, 80e and 120r, B&W GN, BrakeSmart, 'pooned tank, tank and pre-pump mods, 2 Dahl 100 filter, regulated return, BTS dual HPOP, AC singles with EDM 34 lpm nozzles, AIS, H2e, Spearco 6.0 IC, Hypermax 3.5" dp--> MBRP 4" 304SS exhaust, BTS tranny, 203 T-stat, Chevron ELC, coolant filter, Oilguard bypass with Schaeffer 9000, WranglerNW 200 amp alternator & Optima group 31 batteries, Nippon-Denso starter, SPA gauges, SteveRacer mods, Hella 80/100W 9007s, Hella Micro DE foglights, 1000FF driving lights, 220W backup lights, Stancor contactor, Michelin XPS Traction tires, X-Springs, Bilstein shox, custom bumpers but otherwise stock. Nov 30 '99 build engine with 16 K miles, Fluidampr, Comp Cam 910 springs, Melling LPOP and ARP headstuds.
haul_n_horses2 is offline
post #3 of 13 (permalink) Old 07-19-2006, 08:32 AM
Black05's Avatar
Sam -- On mine, its 150 ft lbs. The torque specs are actually stamped on the lug nuts.
Black/05/F350/XLT/CC/LWB/FX4/SRW/3.73/6.0L PSD/ TorqShift/Updated TBC/Upfitter Switches/SEIC Mod/Diesel Site Coolant Filter/Fumoto Valve/ITEC HFCM Drain Plug/Bilstein Shocks/BFG A/T 28565R18/Built September of 2004
Texas Proud.
God Bless our Armed Forces.
Black05 is offline
post #4 of 13 (permalink) Old 07-19-2006, 09:14 AM
My Photos: (17)
Ford sent out a notice to the original owners that the spec had been increased from 150 to 165 ft lbs. My truck came with the 150 ft lbs in the manual but was upgraded with a notice to put in the manual that the new spec was 165.
post #5 of 13 (permalink) Old 07-19-2006, 09:24 AM
Black05's Avatar
Interesting. I have received no such notice from Ford for my truck. Given that yours is a 2002 and mine is a 2005, I wonder what Sam's proper torque spec should be as his is a 2004. Maybe his best bet would be to call a Ford dealer and ask about his particular truck.
Texas Proud.
Black05 is offline
post #6 of 13 (permalink) Old 07-19-2006, 09:38 AM
Yeah, my manual has that page edited. There is a sticker covering that page that completely replaced it. I noticed it right away because the page was so much thicker.
New: 2008 F250 Lariat, CC, LWB, 4X4.
Old: 2006 F250 XLT, Ext. Cab, LWB, FX4.
sullyx7 is offline
post #7 of 13 (permalink) Old 07-19-2006, 10:17 AM
SmokeyWren's Avatar
My Photos: (45)
04/04 F350
Yep. 165 lb/ft for the lugnuts on all '99-up PSDs, including the new ones.
For example, here's the specs in the workshop manual for an '05.
<font class="small">Code:</font><hr /><pre>
2005 F-Super Duty 250-550 Workshop Manual
SECTION 204-04: Wheels and Tires
SPECIFICATIONS Procedure revision date: 07/02/2004
Torque Specifications
Description Nm lb-ft
Spare tire carrier bolts 20 15
8-Lug M14 wheel bolts F250/350 224 165
10-Lug M14 wheel bolts F450/550 224 165
</pre><hr />
SmokeyWren is offline
post #8 of 13 (permalink) Old 07-19-2006, 10:24 AM
teamroper60's Avatar
I just had my front wheels off last Saturday. I looked up the torque specs in my owners manual and it said 150-165. I never received any notice that it had to be 165, nor is there any sticker saying anything different....... [img]/ubbthreads/images/graemlins/shrug.gif[/img]
#43
President and Webmaster
teamroper60 is offline
post #9 of 13 (permalink) Old 07-19-2006, 10:32 AM
SmokeyWren's Avatar
My Photos: (45)
Here's the current specs from the workshop manual for your 2003:
2003 F-Super Duty 250-550/Excursion Workshop Manual
SPECIFICATIONS Procedure revision date: 08/27/2003
8-Lug M14 wheel bolts 224 165
</pre><hr />
BTW, thanks for volunteering for the thankless job of moderator on TheDieselStop. Somebody has to do it. [img]/ubbthreads/images/graemlins/warmsmile.gif[/img]
post #10 of 13 (permalink) Old 07-20-2006, 01:38 AM
468LC's Avatar
What would the spec be for aftermarket wheels using tapered seat lugnuts?
Steve
2006 F350 Lariat, 6.0 PSD CC LB 4X4. 100k miles.
Wix coolant filter, Dynomax Ultraflow exhaust, cat mod, Edge Insight CS/with EGT. Sinister EGR delete, EGR cooler delete, up pipe. Looney Tune via SCT X4. S&B Intake.
Mag-Hytec transmission pan, 08 diff cover.
2" leveling kit. RS9000 Shocks. B&W Turnover Ball/ Companion Hitch. Airlift 5000 airbags.
2012 Heartland 5th wheel. 36' @ 12k pounds.
468LC is offline
post #11 of 13 (permalink) Old 07-20-2006, 03:20 AM
Banned
Check with the wheel manufacturer.... Just a very few months ago I had one with tapered seat lug nuts and an instruction sheet from the wheel manufacturer stating 80 ftlb. Not my cup of tea but, with a photocopy of the instruction sheet stapled to the hard copy, the wheels got 80 ft/lb. The ball, if needed, is in the wheel manufacturers court...
At the same time, I recall another 250 with aftermarket wheels and tapered seat nuts that kept coming loose..... the nuts weren't deep enough to fully seat in the wheels and bottomed on the ends of the studs at just the wrong spot.
Caveate emptor....
GrampyJim is offline
post #12 of 13 (permalink) Old 07-20-2006, 05:03 AM
Don't the instructions read "put a small drop of oil on the lug nut where it rotates on the washer and then torque to 165 ft lbs"??
Scott
99 F250/PSD/SC/6Spd/chipped/K&N Lovin life
2004 F250/6.0/CC/Auto... Not exactly loving life anymore, gave back to momma ford..
2005 F350SRW/6.0/CC/Auto/FX4... OOPS, I left it on his lot. NO tolerance for stealers that try and screw me..
06 F350SRW/6.0/Auto.CC/LWB/4x4 ordered 5/4/05..
VIN recieved 5/17/05. Truck on the dealers floor 6/15/05
5/18/07 49k FLAWLESS miles.. I love this truck
11/17/07: 59k miles: EGR hiccup.. Still love this truck
12/14/09: 95k HARD working Miles.. Front cover puked water, dropped off at dealer, part backordered.. Still love this truck
Scott B is offline
post #13 of 13 (permalink) Old 07-20-2006, 08:07 AM Thread Starter
Thanks everyone.
