1999-2007 General QuestionsGeneral questions related to 1999-2007 Super Duty trucks. If it doesn't fit the other categories, post it here. Gas engine discussion that pertains to all models is allowed. Specific gas engine questions should use the Gas Engines forum.
I want to load a Rhino in the back of my dually and was wondering what people thought about what the tailgate can hold as far as weight?
I have ramps rated at 3000lbs, so that is no issue.
But I don't want to bend my tailgate.
Only 1 axle of the Rhino is on the tailgate at 1 time, so figure around 700lbs.
Inputs?
2006 F350 4X4 Dually, Tow Boss, Crew Cab, Lariat... Inyati Spray In Bedliner, Autometer Z Series Gauges towing a 2006 LE3905 Weekend Warrior
On order: 2012 F350 4X4 Dually, Oxford White, Black Leather, Ultimate Lariat Package
I load an 1100lb small car (plus me) over the tailgate all the time using ramps, have for years on 3 different pickups with no problem. I would probably not press my luck at 3000lbs.
I've got an Arctic Cat 700. I load it with ramps onto the tailgate all the time, no problem. When I have the tool box in the bed, the back wheels of the ATV ride on the tailgate, again no problem. I would not try to run the truck down a dirt road with the ATV on the tailgate though.
2001 F250 SC 4X4 Blue PSD Auto, Cody Gooseneck Hitch, Rancho Shocks and Steering Stabilzer, Tekonsha Prodigy Controller, Garmin Streetpilot 2610 GPS, Walker BTM, 285/75R/16E, Western Diesel Trans-Pyro-Boost, Pillar Mount, Painless fuse panel, In-tank and Pre-pump mods, Slotted Rear Rotors, Slotted and Cross Drilled Front Rotors, Fumoto Valve, Zoodad Mod, Transfer Flow 46 gal tank, Mag-Hytec Differential Cover, Electric Tailgate Lock, IAH Deleted, Coolant Filter, DP-Tuner 80 hp PCM, CCV Mod, 203 Thermostat, Ford AIS Air Filter
1986 Isuzu P'up, 177,673.8 miles.
- Hella headlights (highly recommended)
- DOT C-2 back end (also recommended)
- R-12 air conditioner converted to R-406a. Saved ozone and money
- 4.1:1 final drive converted to 3.4:1. Quieter, better mileage but it's a good thing I live in the flat Midwest.
- 9/22/2007, age 21: Still running well when reluctantly sent away for reincarnation, due to body & frame rust.
