Window Problems - Diesel Forum - TheDieselStop.com
Old 03-04-2005, 02:38 PM   #1 (permalink)
Window Problems
My 2000 superduty electric windows are on the blink They work fine for a few days and then now they want to do all kinds of crazy Stuff. When they act up the the relays in the fuse panel make a clicking noise. The drive side will go up but it chatters all the way up and the relay makes the clicking noise. Some times it goes down on its own when the door is shut. Then it will chatter and inch back up when you hold the switch down. The interior lights also dim and shut off when this happens. I'm guessing its a relay??? There are 4 relays. The 3 on the bottom are all the same. I tried interchangeing them with the same results. The top one seems to be making the chatter. Any help would be appreciated.
Stolle is offline
Old 03-04-2005, 03:21 PM   #2 (permalink)
fordmastertech's Avatar
Re: Window Problems
Check for broken wires in the rubber convolute between the door and body that the wires run in. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
There could be a grounding problem, GEM issues, switch problems or bad relays.
The chattering sounds like dry window tracks. Lube the tracks and window runs with This Stuff.
Excursion Pics
2000 Excursion Limited 4x4 Dark Satin Green Arizona Beige 7.3 DIT, AXDO, 3.73 LS, DP Tuner F5, TERMINATOR II w R-IPR, Adjustable Boost Regulator, Turbomaster, EBPV Delete, Air Dog, ITP Regulated Fuel Return, Fuel Cooler, Tags 1&2, Harpooned Tank, Magnaflow XL Exhaust w Aeroturbine 4040L, Sonnax/Tricumulator, 8 Autometer Sport Comp 4 Gauge A Pillar 4 Gauge Overhead, Ford APCM, Crimestopper Remote Starter With Remote Fast Idle, Ford AIS w Zoodad, W Code Front Modified B Code Rear springs, Rancho RS9000X, Rancho 5406 Stabilizer, Hellwig Rear Sway Bar, BFG Rugged Trail TA, V10 Trans Cooler w Dual Electric Pusher Fans, Coolant Filter, IAH Delete, (((XM))) Line Of Fire Light, Ford Cab Lights, 05 Headlights w GOS Conversion Harness, Jimmi Jammers, 03 Lighted Painted Tow Mirrors w C-BETR, PSD Badges, Pullrite Hitch, Prodigy Brake Controller, Born 01/29/00
fordmastertech is offline
