Re: Windows not rolling moving
I had the same problem with a '02. I let it ride for awhile. It ended up burning my switch out on the drivers door ($110). When the windows won't work pop off the fuse panel and check the large metal circuit breaker, careful it gets very hot! I found mine to be a shorted wire in the drivers side rear door where the wire comes through the rubber boot from the center post to the door. It was shorting out against the window track in the door.
'02 F250 SD 4X4 w/ Offroad Package, 7.3L, Auto., 3.73L-S, Lariat, CC, SWB, SRW,
