Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > General Questions
General Questions General questions related to 1999-2007 Super Duty trucks. If it doesn't fit the other categories, post it here. Gas engine discussion that pertains to all models is allowed. Specific gas engine questions should use the Gas Engines forum.
Old 07-12-2006, 05:51 AM   #1 (permalink)
artherd's Avatar
Wiring Prep circuits' fuse location?
Dumb question, can't find this in the search, in google, or any other forum.
I belive I have found the so called "Wiring Prep" wires, they are sealed with dippable rubber and are floating in the engine bay next to the brake master cyl, where the ECM harness punches through.
But, which wires are which, and to which fuses are they associated? In short, I need a wiring diagram for these babies. It is rather emberasing that I haven't been able to find one in searches, have mercy! [img]/ubbthreads/images/graemlins/smile.gif[/img] PS: see sig for truck production date, it is an early 99 if it matters.
- 99 F350 CC, LB, Dually - 01/98 Production Date - Tommy Gate hydraulic liftgate (awesome & highly recommended.)
- 19.5" Goodyear G622s on F550 wheels front and rear.
- F550 brakes. 1050CFM thermostatic 2nd tranny cooler. Prodigy brake controller.
- 4" exhaust to the turbo. 4-pillar EGT, TRANS, WATER, BOOST.
- Ford Ambulance APCM/AIC. Severe Duty AIS.
- Code 3 2100 LED Lightbar, Perimiter Strobes, LED-X lights, Electric (firetruck type) warning horn & PA.
- 4 batteries, Xantrex 250A automatic battery combiner/splitter.
- Dual Xantrex Prosine 2.0KW inverters for 110/220v, Laser printer/copier, plasma cutter, welder.
artherd is offline
Old 07-12-2006, 10:52 AM   #2 (permalink)
Re: Wiring Prep circuits' fuse location?
Try asking Grampy Jim.
Here is a post he made.
2000 F-350 CC LB DRW Lariat
Kwik 6637, TS Performance 6 Way, Autometer Boost / Pyro, Banks Exhaust Brake w/exhaust routed to exit inside the cab
33' Puma 311QBSS 5`er
Wild and Wonderful West Virginia - Go Mounties!!!
"racing in a rice burner is like racing in the special olympics...even if you win, you're still retarded!" ~Borrowed Quote
crzybowhntr is offline
Old 07-12-2006, 11:43 AM   #3 (permalink)
Black05's Avatar
Check the wires with a circuit tester -- you will find they are not energized. They are merely pass through wires that you can hook to and then find the other end under the driver's dash to hook up to the appropriate power supply.
Black/05/F350/XLT/CC/LWB/FX4/SRW/3.73/6.0L PSD/ TorqShift/Updated TBC/Upfitter Switches/SEIC Mod/Diesel Site Coolant Filter/Fumoto Valve/ITEC HFCM Drain Plug/Bilstein Shocks/BFG A/T 28565R18/Built September of 2004
Texas Proud.
God Bless our Armed Forces.
Black05 is offline
Old 07-12-2006, 05:40 PM   #4 (permalink)
artherd's Avatar
OH... not that exciting then :P These guys must be wrong: "A four-circuit wiring prep in the instrument panel eases the job of mounting aftermarket controls in the cab. The wiring prep is sealed against water leaks from the engine compartment and is on its own fuse-protected circuit. " http://www.truckworld.com/Truck-Test.../f-series.html
Sigh.
artherd is offline
Old 07-13-2006, 02:24 AM   #5 (permalink)
It appears that the "wiring prep" your article is referring to is the connector for the trailer brake controller, located to the right of the steering column, under the dash. Re-read the entire paragraph carefully.
The four wires you see coming out of the harness near the brake booster terminate under the dash (somewhere behind the central junction box) to the left of the steering column.
GrampyJim is offline
