Go Back   Diesel Forum - The Diesel Stop.com > Ford Diesels > Power Strokes 1994-1997 General
Old 07-11-2009, 06:23 PM   #1 (permalink)
1994 F250 7.3 DI, How to read codes
Have a 1994 f250 7.3. Truck quit, have been trying lots of fixes, none work. In one thread I was told that 94 could only be read with OBD 1, unless some magic thing allows OBD 11. I have followed the directions of by ‘Autoray 2000 (with upgrade) & only get ‘Eng not responding’. Any Ideas??
nobull56 is offline
Old 07-11-2009, 06:54 PM   #2 (permalink)
chuckster57's Avatar
First thing to determine is if it's OBD I or II. Since '94 is the year of change IIRC, do you have the trapazoid connector under the dash or the other one in the engine compartment. You might have the OBD II connector and OBD I protocol.
1994 F-350 7.3 IDI Turbo, crew cab, E4OD, LB, Dually Photos
1997 Jayco 323RKS fifth wheel w/2 slides, Air Lift 5000 bags
Train Horns: Pictures here
chuckster57 is offline
Old 07-12-2009, 03:14 AM   #3 (permalink)
Mine's the '94 and it's got an OBDII connector--but the PCM wasn't flashed for it, and the AIC didn't work. I had the PCM reflashed and the AIC now works, but my scanner (Actron) still doesn't work. The Ford protocol just doesn't follow OBDII protocol.
'94 F250 supercab 4x4, original owner, 4.10LS, DIY elec fuel, Tymar air intake, Adrenaline HPOP, Beans tunes on 4 position VA chip, VDO gauges (boost,pyro, outside temp), Ford digital AIC, DPPI downpipe, gutted EBPV and turbo pedestal mod, Con OFE clutch, add-a-leafs front and rear, Monroe Reflex shocks, Milemarker 449SS hubs, towing 25' Mallard travel trailer
coming soon: 6.0 IC
nashvillebill is offline
Old 07-12-2009, 10:18 AM   #4 (permalink)
my truck has both, OBD 1 under hood & OBD11 in the cab. It has a tag under the hood that says 'PCM reprogrammed, Modal #F5TF-12A650 BTE' then a autharation # 95-11-9. does this help?
nobull56 is offline
Old 07-12-2009, 06:30 PM   #5 (permalink)
It should be OBD II then. The only other problem is that PSD's don't follow "normal" OBD II protocols. They have there own, and you need the right reader or software to see if any codes are stored. Auto Enginuity is the software of choice here. I don't have it cause mine is OBD I.
Just for fun: here is a link to retrieve codes using the OBD I connector and an analog volt meter, can't hurt to try
Troublcodes.net Trouble Codes OBD & OBD2 Trouble Codes and Technical info & Tool Store. By BAT Auto Technical
