1995 7.3 low oil pressure indicated ? - Diesel Forum - TheDieselStop.com
post #1 of 11 (permalink) Old 05-01-2008, 08:55 AM Thread Starter
I have been getting a erratic reading on my dash gash gauge. I changed the sender and for a month it looked normal again 250K on the unit. It sounds and runs good. It is kinda creepy to watch the gauge go so far to the left? Does this sound familiar to anyone?
tommygene is offline
post #2 of 11 (permalink) Old 05-01-2008, 09:58 AM
Cratos's Avatar
My Photos: (15)
try a new sending unit or better yet put a real OP gauge on it the factory one is just a on -off switch
2012 XLT SCLB 4X4, FX4 SCLB Camper & Tow package, Dark Pearl Blue. Airlift bags and Wireless Air controller
Cratos is offline
post #3 of 11 (permalink) Old 05-01-2008, 12:58 PM
You can't go by the dash gage...they don't call them idiot gages for nothing. I have both...the dash and a real oil pressure gage. Like you I have changed the oil pressure sending unit several time just to have the dash gage read low again...and again...and again...so with the real oil pressure gage I can see what is really going on...everything reads as it should even when the dash gage has decided to take another nose drive . So my advise is if you are worried about your oil pressure readings then get a real pressure gage so you'll know if there is a real problem or not.
Griz
02 F250, 4X4, 4R100, 3.73, B&M Transmission Pan, Edge CTS Digital Gage, Tymar 4" Exhaust, Tymar Intake & HPX & TS 6 Position Chip. IH Bellowed Up-Pipes, RiffRaff AIH delete plug, Riffraff FRx Kit. 6.0 Transmission Cooler. Dieselsite Coolant filter & Transmission filter & 203 Thermostat & WW2 & TurboMaster & inter-cooler boots. BD CCV filter. Driven Diesel Fuel Tank Mod & Pre-Pump Filter. John Wood's valve body.
Griz is offline
post #4 of 11 (permalink) Old 05-01-2008, 10:00 PM Thread Starter
Oil gauge vs/ oil sender
Can I install the oil pressure gauge in the same port as the sender? or is there a alternate site so you can use both?
1995 and lovinit
post #5 of 11 (permalink) Old 05-01-2008, 11:35 PM
1995 and lovinit
I think most people install their aftermarket sending units on the oil filter housing assembly. There is a pressure port there that works well. If you want to install it on the HPOP unit I would remove the square head screw that one would remove to view the HPOP oil level and install it there instead of removing the stock sending unit. There is another location just aft of the oil filter housing assembly on the block. You'll see a flat spot on the back edge of the block with a screw in it. That works too...
Griz
Griz is offline
post #6 of 11 (permalink) Old 05-02-2008, 12:40 AM Thread Starter
Thanks alot. Like most of us I'm busier that a one legged man in a lower section kicking contest.... again thanks for the heads up. btw what would be normal op for a middle of the road 7.3 psd
post #7 of 11 (permalink) Old 05-02-2008, 11:50 AM
Are you asking a question here because if so I am not sure what you want to know.
Griz
Griz is offline
post #8 of 11 (permalink) Old 05-02-2008, 04:17 PM Thread Starter
Yes ? nominal oil pressure on this unit? Is there a "too Low" number.
I don't have knocking. Just a stupid up and down gauge reading
post #9 of 11 (permalink) Old 05-02-2008, 05:02 PM
Yes ? nominal oil pressure on this unit? Is there a "too Low" number. I don't have knocking. Just a stupid up and down gauge reading
Ford says minimal is 10 psi at idle and 40-70 psi maximum at 3300 rpms. I believe they are assuming your oil is at operating temperatures and you are taking the readings off the HPOP. Anyway where I have mine...I read 15 psi at idle and 38 psi at normal driving rpms and oil at operating temperatures. My sender unit is mounted on the block behind the oil filter housing assembly. I have one of my bypass lines on the oil filter assembly pressure port. You'll see a big difference in pressure readings depending on oil temperature. Not to worry this is normal. Where as your dash gage will read the same no matter what the oil temperature is.
Griz
Griz is offline
post #10 of 11 (permalink) Old 05-03-2008, 12:02 AM Thread Starter
Thanks so much . I 'm off to the parts store for the gauge.
Tom
post #11 of 11 (permalink) Old 05-03-2008, 12:04 AM Thread Starter
By the way Griz. With the super chip what kind of milage do you get?
