1996 7.3 Running Really Rough - Diesel Forum - TheDieselStop.com
Old 10-07-2009, 04:48 PM   #1 (permalink)
I have a 200,000 mile 1996 ford F250 with the PS 7.3. The truck was running perfectly. While driving it a few days ago I noticed an immediate rough running motor, and at idle it was like a gasser missing on one or two pistons. It will barely start. Runs really rough. I drove it for about 2 miles and it did not clear up. It barley starts, runs terrible and can hardly be driven.
To complicate this matter a bit, I have only had the truck for a week. Old owner did supply much information on past repairs and has no idea why it would be running rough. It was running perfectly when I picked it up.
Here is what I know:
Hooked up scanner and there are no codes. It is clear
No check engine light
Fuel pump was replaced about 60K ago
Fuel Filter was replaced about 10K ago and still looks good
Engine oil is clean but was supposed to be changed about 3K ago, looks to clean for a diesel.
Oil pressure appears normal
There is a faint smell of diesel but I cannot see any leaks or fuel sitting on top of the block
CPS was replaced at 150K
After running the truck, although I dont do it for long with it running so rough, there is a very faint air hissing noise near the top of the motor. Not sure exactly where it is coming from.
The truck as 2 fuel tanks. I did switch to the front tank and ran fuel through it over the last few days. It has well over 50% left in the tank. Was running on the rear tank when I bought the truck.
I think its fuel starved, and have not checked fuel pressure yet. I don't have a gauge and I am not sure of an easy way to test fuel pressure from the pump to the injectors or if I should also be looking at the push from the tanks to the fuel pump up front.
What I think should be done (but of course asking for your assistance), is to check the fuel pressures with a pressure gauge. Looking for help here on how to get this accomplished.
Check for any noticeable leaks.
Maybe change the oil to a known diesel oil to make sure there is no issues there? (I cannot see this being an issue, the guy I got the truck from was particularly good about using Rotella for the oil changes).
Any help for this beginner is greatly appreciated.
phlorit is offline
Old 10-07-2009, 05:00 PM   #2 (permalink)
The air hiss may be the ebpv. normal until warmed up, then the butterfly opens. Recommend making the butterfly fly away.
To check fuel psi, look on the left side of the fuel bowl. There is a schrader valve, use a tire psi gauge. A little messy, but will work. 1/8npt if you want to install a guage at that port.
I think you have a burned uvch (under valve cover harness). the injectors wiring/glow plug wiring and grounds run through the core of the gasket via connectors. Open the oil fill cap and sniff for burnt plastic. If you smell burnt plastic, post back and we will then point you towards the next step.
Randy
Midnight black '94 * F-250 * 4x4 * ZF-5 * 3:55 * cc/lwb * RDS Single Shot Stage I's* TDP 6pos chip * BDP electric fuel * BDP D-66 Turbo * IDM Mod * Hypermax 3x4" dp * Authentic Tymar intake* 7.3 Intercooler * gutted ebpv * 4" exhaust & 5" tip * LUK clutch * A-pillar pod w/ Auto Meter NV boost, pyro and water temp gauges * reverse dash lighting and hvac controls * Optima yellow top batts D75/25, both on the right side * HPO X-over mod * manually controlled gp's * cruise control mod * add-a-leaf (front) * AC mod
94strokerace is offline
Old 10-07-2009, 10:30 PM   #3 (permalink)
First, thanks 94Strokerace.. Your guidance helped a bunch. I cannot smell any burnt plastic inside the valve cover.
Next, went and got a US General fuel pressure gauge. Just a basic injector pressure tester. Had the correct schrader female end for the test.
Tested as it sat from my previous notes. The needle did not move from Zero. Thought I had something setup wrong. Truck was running rough as it was before.
Took off gauge and checked it. THere was diesel in the gauge, so it was getting fuel.
Then I, for the sake of doing it, changed out the fuel filter. New gasket of course as well. Started the truck and ran the throttle up to WOT. Now the gauge was sitting at 10PSI at idle, but after the new filter, it was running somewhat normal. Let it idle for a while and then did some WOT 5 second pulls. It was heading up to 30-40 PSI and back down to 10PSI at idle.
Took the truck out.. and ran it around and it felt back to what it was before the issue. Ran well, smooth.
Brought it back and tested the pressure again. 10PSI at idle and 30-40PSI at WOT.
Checked all harness connections and they are old, but look ok. I know this does not matter much.
So, a few thoughts...
1. Bad fuel in the front tank that clogged up a 10,000 mile filter?
2. Bad fuel pump at those pressures?
2. The pressure is still bad, but with potential junk in the filter it just could not push enough fuel?
3. Fuel filter was just bad.
I am not sure what the pressure is supposed to be, but I think it should be up around 60PSI.
I will change the oil for the heck of it and see if that improves the pressure...
Thanks in advance for review of this information....
phlorit is offline
Old 10-08-2009, 12:08 AM   #4 (permalink)
BiodieselPlace's Avatar
Have you checked for fuel leaks in the valley?
I thought you mentionned are smell of diesel.
Those lift pumps are prone to fail.
10 psi at idlle is not enough. 60 psi is about right at higher RPMs.
Something wrong with fuel delivery.
Could be pump, or could be related to pressure regulator, maybe even cloged up strainer on your regulator.
Good luck.
* 96 F250 PSD, CC, SB, 2wd, auto, 3:55s
* 280,000 miles
* Tymar Performance intake
* 10K mod
* FPR shim
* DIY Exhaust Brake
* 3" downpipe
* Rotella Synthetic Engine Oil
* B100 all the way!
BiodieselPlace is offline
Old 10-08-2009, 01:42 AM   #5 (permalink)
Good luck.
Yeah.. I think next steps are to replace the fuel pump, change the oil (making sure there is a good diesel oil in the case), and clean out the regulator and screen very well...
It will be this weekends project.
Took the truck for a drive and it seems to be running ok. Wonder how it will fell with better pressure? Anyway.. I'll update the post after the next actions and let everyone know how the old beast is doing..
phlorit is offline
Old 10-08-2009, 05:16 AM   #6 (permalink)
Excavator's Avatar
My Photos: (11)
pull off oil filler cap and smell in the valve cover. If the harness is burnt under the cover it will smell like burnt wires and you will needd to pull off valve covers and replace the harness's as well as check the connectors outside the valve covers for melted and burnt pins and plastic connectors
Jim Sult / Excavator (we dig it)
Trying to fix it? KISS IT "KEEP IT SIMPLE STUPID"
Avatar- purchased off Ford lot as NON RUNNING ENGINE - I drove it off lot in 1 hour/ my everyday 1996 F250 XLT Ext Cab, Powerstroke, 4x4 Dana 60 , Bilsteins shocks, Greggs MB AutoTrans, Baby Swamps,Tony Wildman Chip, AutoMeter Pyro/Trans/Boost, Tymar intake, MBRP 4 in turbo back exhaust, 209000 miles,D&B HT Starter
1996 F350 XL PowerStroke 4X4 DRW, Auto Trans, Stock Work Dump truck, DDP down pipe,Tymar intake, 113000 miles
1997 F350 XL 2x4 DRW Powerstroke , DP Tuner PCM, 5 speed,Luk Clutch Tymar intake. DPP downpipe, 185,000 miles
Truck Pics
HOME of FIRST Banjo Bolt Ratchet
Fan clutch wrench
Camping Trips
Shifter Tube Repair
Excavator is offline
Old 10-08-2009, 11:53 AM   #7 (permalink)
Had the same thing happen 2 weeks ago on my '96,..... did not smell burnt wires at all, ... replaced the V/C gasket and harnesses, one was burnt, replaced the glow plugs while I was into it, after all that, no difference, called Bean Diesel picked up one of there IDM's, plugged it in and now runs better then new! ....... Basically the burned out harness fried the IDM.
Mark
2011 F250 6.7L Lariat 4x4 Crew/Shortbox - Vermillion Red
mcr96 is offline
Old 10-08-2009, 10:45 PM   #8 (permalink)
Thanks for the feedback... For preventative measures, I will replace the harnesses soon. After running a new fuel filter, and on the back fuel tank, its running pretty good.
Bought a new fuel pump and will be replacing this weekend, changing the oil and testing again.
Next weekend I will replace the 4 harnesses just to make sure. I'll keep everyone posted on how it goes for both.
Pressure right now is 10-12PSI at idle and 40PSI at WOT from the schrader valve on the fuel pump although the truck is running smooth.
phlorit is offline
Old 10-31-2009, 09:33 PM   #9 (permalink)
What is an "IDM"?
Also how much trouble to change the harness and glow plugs, I have a 96 F350 7.3 Powrstroke, 198,000 miles.
whyndell is offline
Old 11-01-2009, 04:47 PM   #10 (permalink)
Originally Posted by whyndell View Post
What is an "IDM"?
IDM = Injector Driver Module.
It is controlled by the PCM and provides power to drive the injector solenoids. Mounted under the hood on the drivers side. It's a metal box with a large connector bolted to it.
If you find burnt pins on either the harness or the UVC gasket connectors, I would just replace the gasket(s) and then you have to splice in a new connector(s) on the hardness side since most likely the connector is burnt. You can get the kits from Ford or Napa.
And, yes, it would be wise to replace all 8 glow plugs since your have the valve covers removed and since you don't know when they were put in.
One more comment that has been brought up already: glow plug shorts, harness short, burnt pins can dammage your IDM. That's exactly what happenned to me a couple months ago...
Good luck
* 280,000 miles
* 10K mod
* FPR shim
* DIY Exhaust Brake
* 3" downpipe
* B100 all the way!
Old 11-02-2009, 04:54 AM   #11 (permalink)
Thanks BiodieselPlace
This will give me a place to start. I'm a new deisel owner bought the truck to pull my 5th wheel.
whyndell is offline
Old 11-03-2009, 12:36 PM   #12 (permalink)
I was not able to get a new gasket kit from NAPA. I had to goto FORD. 80 bucks later my truck ran like a champ. It didnt show anything on the computer either till I did an injector vibrate test. Then it only showed the #2 being bad connection. No plastic smell... Just burned wires. Make sure you plug your glowplugs back in all the way. They can be a pain.
95 F250 7.3 Stock flatbed. 5 spd manual 330K.
BMAC123 is offline
Old 11-06-2009, 02:34 AM   #13 (permalink)
95FORDBOY's Avatar
i had a simalar prblm with mine changed the V/C gaskets that didnt help checked all the same things u have and it ended up being my IPR valve
1995 F350 7.3 PSD Blue White EXCab XLT 4X4 ZF5 * 349,000 KM * super duty Intercooler * DP Tuner * south bend clutch *ultra light HPOP , pyro and Boost Gauges * Customized 4" straight pipe no kitty * IDM MOD * AFE/Tymar * Viair Onboard train horns* custom winch bumper 12000 warn * royal purple everywere * 37/12.5/17E on 197 american racing * 4" lift* 6pc crystal headlights ,6000k HID's, 6" spots 6000k HID's*
95FORDBOY is offline
Old 11-06-2009, 02:46 AM   #14 (permalink)
my f350 disel is leaking disel inside the radiator and it is coming out of the water resibore i dont know what is wrong but the truck is runing perfect
7867111 is offline
Old 11-06-2009, 04:50 AM   #15 (permalink)
That sounds like injector cups. A couple of special tools will be required and a specific loctite as well. There used to be a set floating around from member to member as needed, but have fell off the radar, not sure what has happened to them, but maybe they will resurface if you ask....
The cups can be had from powerstrokeshop.com
Randy
