1996 f 250 7.3 diesel will not crank - Diesel Forum - TheDieselStop.com
post #1 of 3 (permalink) Old 05-11-2012, 11:05 AM Thread Starter
The engine was running very bad did not smoke, then just stopped. I started to investigate and ran a buzz test ang got multiple codes on the on the even cylinders and occasional failures on the injector driver module. I checked the driver module and found it to have water in it so I replaced it. I the replaced the connectors and the valve cover gasket on the b bank and the buzz test now passes. The truck still will not crank. I replaced the cps with one from Advance Auto, the tach is moving when I attempt to crank it. The wait to start is lit. The engine turns over rapidly when I attempt to crank it but it does not start.
olinmc is offline
post #2 of 3 (permalink) Old 05-11-2012, 03:01 PM
Patrick Feeley's Avatar
My Photos: (19)
White smoke when trying to start? Is the HPOP reservoir full? What's fuel pressure when cranking? Check the fuel bowl wiring harness wiring, especially the wires for the IPR. Cheers!
97 F250 SC 4x4 (CA model), E4OD, 4.10 LS,
, Ext Trans Filter, Tru-Cool Max, I/C Mounted but not Plumbed
SOLD: 94 F350 CC DRW, 5 Speed, SBC Con-O,
, 3 DP, Bilsteins,
, Gutted EBPV
Patrick Feeley is offline
post #3 of 3 (permalink) Old 05-11-2012, 05:00 PM
Also check the under hood fuse #22. Might have jiggled the fuel bowl heater wire and blew the fuse.
AaronSEIA
My Truck:
97 F250 4 door shortbed, E4OD
DIY intake
Kingpin Dana 60
otherwise stock
AaronSEIA is offline
