1996 F350 tranny shifting hard - Diesel Forum - TheDieselStop.com
post #1 of 7 (permalink) Old 02-05-2008, 01:33 PM Thread Starter
Unhappy 1996 F350 tranny shifting hard
I have a 1996 F350 4x4..the o/d light will start blinking and the tranny will start shifting hard..super chip diag code p1728..I can clear the code and it will run fine for 1/2 day or so then repeat.. leaking some fluid.. any suggestions??? I read something about a modulator valve but don't know if it applies here..Thanks Walker
rack ranch is offline
post #2 of 7 (permalink) Old 02-05-2008, 01:57 PM
Mark Kovalsky's Avatar
My Photos: (6)
There's no modulator valve on your transmission.
Most likely your torque converter clutch has failed. When it starts to slip the PCM sees that, sets a code (P1728), flashes the OD light, and puts the trans in high line pressure mode to help prevent more damage. The high line pressure causes harsh shifts.
Mark
Former
Automatic Transmission Engineer 1988-2007
Mark Kovalsky is offline
post #3 of 7 (permalink) Old 02-05-2008, 02:21 PM Thread Starter
Thanks Mark..this problem started about 4 months ago and I've been resetting the code and continuing to drive it..even pulling trailors with it ( I know I know)..does your diagnosis still fit ??? and if so do I just replace the converter ??Walker
post #4 of 7 (permalink) Old 02-05-2008, 02:24 PM
Invader1's Avatar
Get it in to a tranny shop quick and have them install a heavy duty triple clutch TC. Like Mark K said it is your TC slipping. If you wait to long it will contaminate the entire tranny and you will need a full rebuild. This may be the case already but if it just started, you may be able to get away with just putting in a new TC. I have been where you are and went a long time with just changing the TC.
Just don't put in another plain stock TC. The trannys are the week point in these trucks and the stock TC is the week point of these trannys, (at least one of the main week points).
Invader
97 F250 XLT SuperCab LB E4OD
Mod's: Tony Wildman 4 page chip, Stealth HPOP, Beans fuel system, JoeServo high voltage IDM, Swamps 175/173 injectors, Hypermax H2E turbo and inter-cooler, open element air filter, Down pipe, open exhaust, exiting in front of rear wheel, with dynomax bullet race muffler. Home made, dual stage, Propane system, ATS TripleLoc billet steel Torque converter. Imperial Shift Kit, BD PressureLok. Mag-Hytec tranny pan and rear cover, ARB air locker in the rear.
,(part # 112). 4" Superlift lift kit, Air lift air bags with Smart air auto leveling system in the rear, Full instrumentation, Grant steering wheel, on board air system. Putco skins stainless bed rail/tailgate covers. Stainless Nerf bars. Billet front grill and clear lenses all the way around.
Invader1 is offline
post #5 of 7 (permalink) Old 02-05-2008, 08:41 PM Thread Starter
Any other opinions ??? will the tc problem show up on a diagnostic test?? Walker
post #6 of 7 (permalink) Old 02-06-2008, 08:08 AM
My Photos: (6)
The torque converter problem should show up if the tech has the proper tools and knows what he's doing.
Mark
Former
post #7 of 7 (permalink) Old 02-06-2008, 05:50 PM
Vehicle speed sensor is bad, wires to it or bad or the damn gear wheel in the rear diff is missing teeth. I replaced my vss, and the wires. my problem is in the rear end. it puts the trans in limp mode and makes it shift hard. You may notice the mph guage bouncing after 60mph if this is the case.
2003 F350 crew cab 4x4 , 295's on 17's, performance MFG coolant filer, Blue spring, new HFCM, FICM, Batteries and Alt. SCT performance tune, 128k on engine 12/13. Stock everything else.
ryhed is offline
