1997 Ford Powerstroke diesel IDM Module Problems - Diesel Forum - TheDieselStop.com
post #1 of 11 (permalink) Old 09-25-2008, 11:46 AM Thread Starter
Hello, I have a 1997 Ford International 7.3 liter powerstroke diesel. I have been having problems with it so I took it to the shop, and they said it was
the IDM Module. Does anyone know what that is, or where it is located??
I would like to fix it myself if possible, Thanks.
safesidegirl is offline
post #2 of 11 (permalink) Old 09-25-2008, 12:08 PM
IDM/PCM pictures from friends & fun photos on webshots
What are the symptoms ?..
IDM 's on ebay all the time $ 2-300.00
Rick.....
97 F 350 ...Lucky 13
"Most stuff's just stuck & needs hittin with a hammer .Supporter/End user of ShiftSolutions THE CURE E4/4R Trans Control. Helping Cancer patients and families
Special thanks to RacerX USA
action4478 is offline
post #3 of 11 (permalink) Old 09-25-2008, 10:38 PM
Patrick Feeley's Avatar
My Photos: (19)
Welcome to the forum, safesidegirl!
The injector driver module provides the high voltage (120V or so) to activate the injectors to inject the fuel when commanded by the truck's computer. It is the silver box just under the driver's side hood hinge. Any IDM from a 7.3L Powerstroke engine will work and replacement is easy. If you have the time to hunt on ebay, you can find them for cheap (at least you used to be able to ... I've got two spares that I paid $50 each for a few years ago). A lot of times the IDM gets blamed for other problems such as burned/melted injector/glowplug wiring harnesses, but they can go bad due to water leakage or burned internal electronics. As Rick mentioned above, are there particular symptoms your truck was exhibiting? Cheers!
97 F250 SC 4x4 (CA model), E4OD, 4.10 LS,
, Ext Trans Filter, Tru-Cool Max, I/C Mounted but not Plumbed
SOLD: 94 F350 CC DRW, 5 Speed, SBC Con-O,
, 3 DP, Bilsteins,
, Gutted EBPV
Patrick Feeley is offline
post #4 of 11 (permalink) Old 09-28-2008, 09:17 PM
dennis11's Avatar
Idm
I was lucky and took my truck to the local ford dealer and paid $834 yes eight hundred and thirty four dollars american. Plus $300 for diagnosis and instalation. Be sure and not go to ford to purchase an IDM. I took my first and last lession about the local ford dealer. Just for your info if you did not already know.
1997 F250 PS 4 wheel drive John Wood towmaster tranny with Tru-cool tranny cooler and second Summitt tranny cooler with pusher fan on at 175 degrees, tranny temp gauge 4:10 gears aluminum diff cover with royal purple supercab flat bed, stancor glo plug relay, factory aluminum rims Firestone ride rite airbags rear 430,600 miles. 2002 F350 PS 4 wheel drive, 215,000 miles. Stock. Will be adding to make it my road tow vehicle to Vegas. Just added 31 row 6.0 cooler with Isspro tranny temp gauge and steering column mount.
dennis11 is offline
post #5 of 11 (permalink) Old 09-29-2008, 11:22 AM Thread Starter
( Symptoms= Feels like its running on only 2 0r 3 cylinders. Rough riding, feels like It's not going to make it home, not much power.)
Thank you all so much for all the information!! It has been a great help.
I have located the IDM Module and am going to try and fix it now. I'll let you know how it goes. Thanks again!! Have a great day.
post #6 of 11 (permalink) Old 09-29-2008, 12:12 PM
Are you getting a check engine light ?..
Before you spend alot on an IDM ,it may be worth having the scanned & a buzz test for codes...
Rick.....
post #7 of 11 (permalink) Old 11-25-2008, 11:12 PM
IDM Location
I have an 03 Excursion with a bad IDM. I have been told by several different people, the module is
1 under the hinge on the drivers side
2 I have to remove the wheel well on the drivers side to find it
3 it is attached to a valve cover
I have even removed the battery and air filter assembly to see if it was under it.
Did Ford hide it somewhere special on the Excursion?
Soundguy is offline
post #8 of 11 (permalink) Old 11-27-2008, 08:19 PM
Feedback Score: 3 reviews
on superdutys and ex's it is located in #2.
on the obs it is location 1
and on a 6.0 it is in 3
Dads ride 2002 Dodge 24v, dual exhaust, edge comp hot box. tst 40 hp injectors,Piers B-1 turbo dipricol white face a pillar gauges, Suncoast triple disc and valve body occasionally he lets me drive it. 393 rwhp, 807 ftlbs
1996 F-350 CC swr, long bed , 4x4 PSD zf-5, 260k.Swamped, 5" black stacks, dipricol gauges, 30+PSI boost, DP tuner chip, 349rwhp.
95 PSD project fixes it up and then sold it
03 7.3 4R100 4x2(for now) 240k stock cept for duals 20th aniversary edition.
early 99 CC Dually,
finallygotanIDI is offline
post #9 of 11 (permalink) Old 12-01-2008, 07:13 PM
Thanks, it was behind the wheel well
I was hoping it was in an easier location. I had to remove the running board and the clips for the fender flair to get at the wheel well.
Soundguy is offline
post #10 of 11 (permalink) Old 10-25-2015, 04:17 PM
97 ford turbo diesel
1997 turbo diesel 7.3 quiet running its getting fuel its not crank cencer its cranks over but wont start what could it be
bus driver is offline
post #11 of 11 (permalink) Old 10-28-2015, 08:24 PM
I'd suggest you start a new thread. Describe your problem, what remedies you've tried, any codes you've pulled, mileage, etc.
Oh...and try to use some punctuation in your post.
Kimber1911 is offline
