285's on Stock '96 rims?!? - Diesel Forum - TheDieselStop.com
Old 11-12-2009, 01:50 PM   #1 (permalink)
Hey guys,
Just a quick question. I am wanting to go with 285's on my stock rims. Will I be rubbing anywhere?? I know some guys don't like the thought of 285's on a thinner rim, but that is not my question.
2005 Excursion Limited, 6.0L PSD, 4wd. Mods by Rudy's Diesel Performance: Powermax Turbo, new oil cooler, EGR cooler delete, Head Studs, S&B Intake, SCT tuner w/ custom tunes, Edge Insight CS.
1996 F-250, 7.3L PSD, crewcab, 4wd, 295/75R16 Terra Grapplers
6LMonster is offline
Old 11-12-2009, 01:58 PM   #2 (permalink)
That's what I've had for over 10 years, 285's on the stock steel rims. No rubbing issues even before I added the leaf up front.
'94 F250 supercab 4x4, original owner, 4.10LS, DIY elec fuel, Tymar air intake, Adrenaline HPOP, Beans tunes on 4 position VA chip, VDO gauges (boost,pyro, outside temp), Ford digital AIC, DPPI downpipe, gutted EBPV and turbo pedestal mod, Con OFE clutch, add-a-leafs front and rear, Monroe Reflex shocks, Milemarker 449SS hubs, towing 25' Mallard travel trailer
coming soon: 6.0 IC
nashvillebill is offline
Old 11-12-2009, 06:38 PM   #3 (permalink)
Im running 295 Nitto's now...no prob
Randy
Midnight black '94 * F-250 * 4x4 * ZF-5 * 3:55 * cc/lwb * RDS Single Shot Stage I's* TDP 6pos chip * BDP electric fuel * BDP D-66 Turbo * IDM Mod * Hypermax 3x4" dp * Authentic Tymar intake* 7.3 Intercooler * gutted ebpv * 4" exhaust & 5" tip * LUK clutch * A-pillar pod w/ Auto Meter NV boost, pyro and water temp gauges * reverse dash lighting and hvac controls * Optima yellow top batts D75/25, both on the right side * HPO X-over mod * manually controlled gp's * cruise control mod * add-a-leaf (front) * AC mod
94strokerace is offline
Old 11-13-2009, 07:22 AM   #4 (permalink)
How do you like your Nitto's?
Old 11-14-2009, 11:54 PM   #5 (permalink)
Parky66's Avatar
My Photos: (5)
315 BFG's no problems, just had to trim the inside bumper a tad !!!
Mike Parker - Parky66
1996 F-250 Ext Cab
Long Bed, 4X4, 7.3 PSD
(ZF5) 5-Speed Transmission
(Twildman's) 4 Position Chip
Auto Meter Cobalt Series Gauges on Full A-Pillar
Tymar Intake
(DPP) 3" Downpipe
(DPP) Catalytic Converter Delete Pipe
Lund Moon Visor
RCI 2950
Kenwood MP3 Player
Parky66 is offline
Old 11-15-2009, 12:52 AM   #6 (permalink)
My Photos: (60)
95 2 wd with 285/75, only problem was a minor rub on the front torque arms at a full lock turn that you should not have on a 4x4.
THANK YOU to all the heroes in our military and all the heroes at home who wait for their safe return. I am humbled by and grateful for your service and sacrifice.
LINK TO LIST OF THE FALLEN
'95 F250 ext cab long bed, PSD, 5 speed, 2 wheel drive, 3.55 gears, 286,000 miles, Edge Evolution CTS (LINK TO MY REVIEW), LUK clutch, homemade REAR BUMPER, open element AIR FILTER, 36" ARE contractor cap. With tools, full of fuel and me on board (300 lbs) steer 3620, drive 3860 total 7480.
Believer45 is offline
Old 11-15-2009, 01:03 AM   #7 (permalink)
DaveBey's Avatar
My Photos: (203)
The 285/75R16 is about as high as you can go without rubbing. 315/75R16 is the about the biggest you can go on the stock 16x7 wheels but will rub and it's not recommended on the F-250/Dana 50 front axle without some aftermarket suspension parts.
That being said, I've had Dayton Timberline 285/75R16, Cooper Discoverer 285/75R16, Wild Country 255/75R16, and now Wild Country 285/75R16 on my F-350 and the Dayton's lasted right at 50,000 miles.
Bottom line, 285/75R16 tires are just fine on a stock rim.
Cheers from Claremore, OK!
Dave
1996 F-350 XLT CC SRW 4x4 BTS-E4OD●4L10●Tyrant Diesel chip●Hypermax H2E, intercooler, exhaust●TE-T500●7.3L Regulated Return Fuel System●215 amp generator●International water pump●Hydro-Boost●6.0L Fan●APCM 245,000 happy miles
DZLJIM 3:16
~~NTxPSA - Hold my beer and watch this.~~
DaveBey is offline
Old 11-16-2009, 07:22 AM   #8 (permalink)
That is great news. Thanks guys!
Old 11-16-2009, 06:27 PM   #9 (permalink)
295/17 Nitto Terra Grapplers and i love 'em! No rub. Previous tires (2 sets) of 285 BFG KO's and were ok, but loaded up quickly. These Nitto's are bad azz, quite as the KO's are and are CHEAPER.
Randy
Old 11-17-2009, 07:58 PM   #10 (permalink)
i run 285s on my stock aluminum wheels on my 97 and no rub what so ever, even when in a bind. they are also nitto terra grapplers and like 94strokerace said i love them. the are alot cheaper and they last just as long i got almost thirty thousand on mine and still prob half tread maybe little less. if your truck 4x4 i say go for it you should have no troubles!
happy trucking
ERIC
97 F-250 Red ext.cab long bed 4X4 junky slush box e4od 4.10 gears no muffler, new power steering pump, vaccum pump, fuel pump,water pump, fuel heater un plugged, k&n air filter, waste oil powered free fuel nothing like stickin it to the man 217,000 still running strong
67 F-100 Ranger 351 W auto my first truck
93 mazda b2600i auto 143,000
wifes ride 98 lincoln navigator
used to own:
01 F350 psd crew cab 4X4 junky e4od
f350powerstroke01 is offline
Old 11-17-2009, 11:13 PM   #11 (permalink)
There's another option too. 285/60-16 tires. With this size the width is more than enough to be way out of spec for a 7" wheel which is very desirable, plus the height is low enough to not rub. You can get kind of a low rider type look. Also either 285 will crown due to too small wheel for the tire, which is what you want so you get kind of a rounded profile motorcycle tire effect.
1997 F350CC, 4x4, PSD Tipper pro kleenex open filter. Roggen 6" lift kit with 26" ratflex 12" offset tires. Downpipe cut and welded to adapt 3" into a 12" outlet. 12" muffler cut and adapted to 2", then a special turbo manifold from a volkswagon modified to flank out to 3" to the tail pipe. Interior from a Corvair modified by cutting 6" off the padding. Snize and snide 32gallon aux tank mounted in rear seat, rear seat relocated to bed. Bed shortened to 4ft.
RonKZ650 is online now
Old 11-18-2009, 07:16 AM   #12 (permalink)
Ron, you are right, a quarter inch on each side is WAY out of spec!!!! Sheesh. Read the original post before you leave a comment.
Old 04-08-2010, 04:32 PM   #13 (permalink)
Alright guys, here is an update!!! I went with 295/75R16 Nitto Terra Grapplers! They are great and they ride smooth. I just had to trim a little off the inside of the bumper. Thanks for all the feedback!
