7.3 exhaust manifold gasket leak/replacement??? - Diesel Forum - TheDieselStop.com
post #1 of 7 (permalink) Old 09-30-2006, 06:19 PM Thread Starter
I have a 95 7.3 in a f450 2wd I just got done putting a new stock turbo on it and noticed the exhaust manifols had leaks on both rear cylinders.After I installed the new turbo it seems to be lacking the power that it use to have,and I can hear the exhaust leak getting louder and louder under a load pulling a trailer.Will I have to pull the engine to change the gaskets?Also wondering if the bolts on these come out easy or break off like common ford motors in the past?would these leaks cause a noticable power loss?thanks for any info
outlaws51 is offline
post #2 of 7 (permalink) Old 09-30-2006, 07:40 PM
BlueMule's Avatar
My Photos: (12)
Re: 7.3 exhaust manifold gasket leak/replacement???
When the motor was originally assembled at the factory they didn't use manifold gaskets, but they are available.
The manifolds can be removed without pulling the engine. The inner fender can be loosened up and pulled out of the way so you can work thru the wheelwells.
Any exhaust that is leaking before the turbo will cause a loose of power because that exhaust is being wasted instead of being used to spool the turbo and build power.
And yes these manifols bolts like to break off in the head. As a matter of fact that could be the source of your leak, is fairly common for them to break even before you get near them with a wrench.
Rodney#33
BlueMule is offline
post #3 of 7 (permalink) Old 09-30-2006, 09:51 PM
Patrick Feeley's Avatar
My Photos: (19)
Here's the factory gasket part numbers (as was mentioned there are no gaskets on them from the factory):
Exhaust Manifold Gasket
(Ford) F4TZ-9448-A
(International) 1814219C1
Cheers!
97 F250 SC 4x4 (CA model), E4OD, 4.10 LS,
, Ext Trans Filter, Tru-Cool Max, I/C Mounted but not Plumbed
SOLD: 94 F350 CC DRW, 5 Speed, SBC Con-O,
, 3 DP, Bilsteins,
, Gutted EBPV
Patrick Feeley is offline
post #4 of 7 (permalink) Old 10-01-2006, 07:15 AM
i'm having the same problem, but its just on my drivers side. How do you remove broke bolts? I don't know if any of mine are broke, but i want to be prepaired before starting the project of fixing it. Also should i buy all new bolts?
96' F350 4X4. E4OD tranny running Amsoil synthetic, 1 big tranny cooler and tricumulator springs and accumulator valve. Autometer guages, homemade intake, TS 6 position Chip (tuning by
, Factory AIC, A/C mod, MBRP 4" Exaust, BDP Stage I injectors, Brakesmart trailer brake controller, T/C lockup switch
Soon to be installed: Innercooler (sittin at the shop), Big Oil, Built Tranny, Coolant Filter, HX hose, and some others. 350k miles.
TimMiller is offline
post #5 of 7 (permalink) Old 10-01-2006, 09:27 AM
My Photos: (9)
Are you sure about that? The ones I have seen have stainless steel stamped gaskets OE. Maybe they changed somewhere along the line?
Birken
Birken Vogt is offline
post #6 of 7 (permalink) Old 10-01-2006, 12:05 PM
fourhatz's Avatar
Yep, never has gaskets from the factory.
96' F-250 4x4 SB Crewcab, 3.55 gears, rebuilt E4od, Air bags, 2" leveler kit, 10 disc cd changer, Tymar intake, Tymar 4 pos TS chip, 4590 cooler, boost, pyro(pre-turbo) & tranny temp AutoMeter gauges mounted in pillar, Diamond eye 4" exhaust with lost kitty, Tymar 3x4" downpipe, Warn hubs, Prodigy brake controller, Hypermax intercooler, CCV mod,17* HPOP, stage 1 injectors, fpr. Rebuilt tranny with pump and valve body mods, 3 disc torque convertor. Diesel mechanic 20+ years
fourhatz is offline
post #7 of 7 (permalink) Old 04-24-2014, 02:57 PM
Time for me to pull the manifolds and install gaskets too. Are there any "while you are in there" suggestions you guys recommend? I'm thinking maybe the up/down pipe gaskets at the same time?
huntnphool is offline
