7.3 fuel filter heater connector - Diesel Forum - TheDieselStop.com
post #1 of 10 (permalink) Old 10-13-2012, 02:17 PM Thread Starter
My fuel filter heater connector broke and I need a new one or used one doesn't matter. The part number is F4TZ-9S277-A. Thanks!
janelldawn92 is offline
post #2 of 10 (permalink) Old 10-13-2012, 03:52 PM
bugman's Avatar
My Photos: (12)
NAPA carries the Dorman one, Autozone might also. Or you can leave it unplugged.
bugman is offline
post #3 of 10 (permalink) Old 10-13-2012, 04:02 PM
A lot of guys unplug them as they are known for blowing a fuse that runs a lot of stuff.
AaronSEIA
My Truck:
97 F250 4 door shortbed, E4OD
DIY intake
Kingpin Dana 60
otherwise stock
AaronSEIA is offline
post #4 of 10 (permalink) Old 10-13-2012, 04:26 PM Thread Starter
I got a new heater just need a new connecter
post #5 of 10 (permalink) Old 10-13-2012, 08:44 PM
Maybe take the heater to RadioShack and try to match the end to something? A good car parts store should have a connector as well.
AaronSEIA
My Truck:
DIY intake
Kingpin Dana 60
otherwise stock
post #6 of 10 (permalink) Old 10-30-2012, 02:14 PM
There's an electrical parts house called AuVeCo that may have a local shop near you; if not, find them online. They have every kind of auto connector imaginable. As to your heater, if you haven't damaged the new one, take it back for a refund. You do not need it, and as noted above, they're prone to failure and when they do they blow #22 (IIRC) maxifuse and cut the power to the PCM (the brain) and you're dead at the side of the road. If your connector isn't leaking fuel, then snip the wire, cap the ends, and the hell with it. I live in NW Ohio; it gets plenty cold here and I've never had an issue as a result of removing the fuel heater element about eight years ago.
'96 F350 XLT CC 4x4 PSD auto LWB 4.10 open, white, open intake, Tymar HX, 3"DPP downpipe, 315 General A/T on factory Alcoas, F add-a-leaf, new alt x3, fuel pump x3, water pump x2, vac pump x 3, PS pump x3, SD starter x3, rebuilt seats, total poly bushing kit, serious noise reduction, new tan interior and vinyl floor, Bilsteins, Bean's Stage 1s, Tony Wildman 4-pos chip (wow), etc ad infinitum, newer black Lab in backseat, locally rebuilt tranny & new TC @ 211k, complete body 'makeover' and repaint @ 213k, new fast-spool turbo 7/11, 317k miles on 18 Oct '14; probably won't run forever but neither will I
JoshR is offline
post #7 of 10 (permalink) Old 10-30-2012, 03:23 PM
Patrick Feeley's Avatar
My Photos: (19)
If you are refering to the connector on the fuel bowl itself that the fuel heater plugs into on the inside and the harness plugs into on the outside (I'll call it the fuel heater feedthrough), note that it is not just a direct passthrough. It does have some sort of "thermostat" function. The part number for it is F4TZ-9J294-A. Tousley Ford Parts online should have it for about $40.
97 F250 SC 4x4 (CA model), E4OD, 4.10 LS,
, Ext Trans Filter, Tru-Cool Max, I/C Mounted but not Plumbed
SOLD: 94 F350 CC DRW, 5 Speed, SBC Con-O,
, 3 DP, Bilsteins,
, Gutted EBPV
Patrick Feeley is offline
post #8 of 10 (permalink) Old 10-30-2012, 04:15 PM
blageurt's Avatar
My Photos: (9)
I would just leave it disconnected.....If you use anti-gel additives and make sure fuel filter is good , you don't need it...It gets -25 C here in winter and I have never had a problem....I use Power Service religously however ...( white in winter and Grey in Summer )
95 E350 PSD HD Cargo , BB shim , E4OD , B&M aluminium Trans pan , Twin HD coolers , Cat sleeps with the fishes , 3:55 D60FF, EBPV Delete , DP flashed 60 Tow , 140 V idm , Autometer Triple pod , Bridgestone /Hankook
1977 F350 Dually Dump , 460 , 429 POLICE heads , 4:56 D70FF, Edelbrock Intake , Holley 850 , MSD IGN , Custom C-6 Trans , Dual Exhausts , Bridgestone
blageurt is offline
post #9 of 10 (permalink) Old 10-31-2012, 11:18 AM
Patrick - Are you sure of the thermostat function of the fuel heater? I recall reading here that the three 'solder' joints (the ones that fail and allow the element to short out by touching the canister) are "thermistors" and thus transmit some sort of changed electrical value to (I'm guessing) the PCM, depending on temperature, but I don't recall ever reading how the PCM uses this or how my engine's performance might be affected by eliminating the heater from the info stream. Can you shed any light on this?
JoshR is offline
post #10 of 10 (permalink) Old 10-31-2012, 03:44 PM
My Photos: (19)
I just remember someone posting (I don't remember what PSD forum it was) that they took some measurements of the part and it was not a "direct" feedthrough and it was more like a thermistor. The PCM does not monitor any parameters associated with the fuel heater circuit (the circuit is simply powered off the same power feed used for one of the PCM feeds). Eliminating the fuel heater will not have any effect on performance (mine has been disconnected for a few years now). Cheers!
, 3 DP, Bilsteins,
, Gutted EBPV
