7.3 idi zf-5 tranny to 96 powerstroke motor - Diesel Forum - TheDieselStop.com
post #1 of 2 (permalink) Old 01-04-2012, 09:11 PM Thread Starter
rednexx's Avatar
My Photos: (20)
Will this tranny bolt up to this motor. I'm doing a powerstroke auto swap into an 92' that has an IDI that has a 5 speed. Are the bell housings the same and which clutch combo is needed.
Early 99 F-250 Superduty X/C SB, 6 speed, South Bend Con OFE clutch, 4" turbo back exhaust, Ebpv Brake Mod, DIY Tymar, Hutch Mod, 2" leveling kit, 315/75/16's, DP tuner ( 60tow, 80econo, 120race, 140extreme), Warn premium hubs, Autometer pyro, boost, tranny, and fuel pressure gauges. AE if anyone in the area needs.
76' (updated) E series 24' Motorhome - 94' 7.3IDI w/ATS turbo (Brand spank'in new turbo spec motor
) ZF 5 speed, LUK clutch, Borg Warner 1356 transfercase, dana 60 front, 3.73 gears, 245/75/16, and its a 4x4 too!
My Gallery
Next........MORE!!!:
rednexx is offline
post #2 of 2 (permalink) Old 01-04-2012, 09:37 PM
1dieselman's Avatar
My Photos: (12)
Yes the IDI ZF5 will bolt to the powerstroke. I would keep the powerstroke clutch setup if possible. The powerstroke used a larger clutch disc than the IDI, but IIRC the factory turbo 7.3 idi went to the larger clutch disc also. But if you have the Idi clutch package already it should work fine.
Jack
97 F250 XLT CCSB 4x4, Dana 60 swap, custom built E4od, Baby swamps, 1.0 turbo housing, deleted ebpv, 203* t-stat, high pressure X line, Diy 140v Idm, 6.0 fan, Diy 6637, tunes by Dp tuners, Isspro Ev gauges, Diy intercooled, 3" downpipe 4" exhaust, 6" lift, 4:10 gears, 35" tires, 315,000 miles
1dieselman is offline
