7.3 won't start when hot - Diesel Forum - TheDieselStop.com
Old 11-09-2008, 07:28 PM   #1 (permalink)
hey there, can anyone help me here? I have a 96 7.3 that will not start when hot but it will fire right up if you compression start it
BANDHAULER is offline   Reply With Quote Quick reply to this message
Old 11-09-2008, 08:40 PM   #2 (permalink)
I had same problem, ended up replacing the IPR. Also had to clean the chip and PCM service port contacts where the chip plugs in.
02' F-350 XLT Super Cab 4x4, 4R100 w/Factory Tech Valve Body & Mag-Hytec pan , 3.73's w/ Detroit Lockers Frt & Rear, SS Y-Pipe, Ford Motorsports headers, Bilstein Shocks, Western Pro Plow
tcgrmt is offline   Reply With Quote Quick reply to this message
Old 11-09-2008, 09:54 PM   #3 (permalink)
Patrick Feeley's Avatar
My Photos: (19)
No start when hot is usually an indication of bad IPR (injection pressure regulator) o-rings. You can try that first as it is a lot cheaper than replacing the entire IPR. Here's the part number:
IPR O-Ring Kit (for when IPR valve replacement is not required)
(Ford) F6TZ-9C977-AA
(International) 1825806C92
Cheers!
97 F250 SC 4x4 (CA model), E4OD, 4.10 LS, Relocated Block Heater Plug, Ext Trans Filter, Tru-Cool Max, I/C Mounted but not Plumbed
SOLD: 94 F350 CC DRW, 5 Speed, SBC Con-O, Baldwin Filter, Tymar HPX Hose, 3 DP, Bilsteins, $12 AIC, Coolant Filter, Explorer O/H Console, Trans Temp, Boost, and Pyro, Pedestal Mod, Gutted EBPV
Patrick Feeley is offline   Reply With Quote Quick reply to this message
Old 11-09-2008, 10:58 PM   #4 (permalink)
thanks for the info. however the fact that it will bump start right away when hot tells me it is still getting fuel. I'm lost here.... why would it still bump start if the o rings are bad?
Old 11-09-2008, 11:20 PM   #5 (permalink)
STurbo90's Avatar
My Photos: (9)
The pcm needs to see 500 psi on the icp sensor before it will fire the injectors. If the ipr is faulty or the ipr 0-rings, or other items related to the high pressure oil system are faulty it might not be able to build adequate pressure from the rpms generated by the starter motor alone.
1995 F350 PSD,CC,LB,E4OD,4WDw4:10LS
IDM Corrosion
Underdash Gauge Pod
Front Tow Hooks
STurbo90 is offline   Reply With Quote Quick reply to this message
Old 11-10-2008, 07:48 AM   #6 (permalink)
That definitely sounds like the ipr o-ring issue. My son's 95 had the "won't start when hot" issue. I searched and searched the internet and everything pointed to IPR orings. I told him what it could be but he just had to take to a diesel performance shop. Keep in mind that my kid wants to be a diesel mechanic (he's 17). The owner of this shop hooked it up to his laptop and read a bunch of values and deetermined that the IDM was bad. So, by then the truck was already cooled off, so my son drove it home and commenced to switching IDMs from my 96. Meanwhile, I already called International and had the IPR reseal kit (large o-ring, small o-ring, split o-ring, spacer and nut) waiting on me. I got home and low and behold the 96 IDM had the same result. I handed him the kit, he pulled the IPR out and the small o-ring was split. Cleaned it all up, installed the kit and now she starts every time.
This is my first stop for anything related with any of my trucks. Take the majority consensus and it is usually right.
Just goes to show you that this forum has more knowledge than many believe.
2005 F250 LARIAT CC 4X4 6.0L PARROT CK3200 bluetooth car kit, Shaker 500 system, nice set of train horns, twin viair compressors and 5gal tank, 5" MBRP turbo back, AFE stage II intake, SCT tuner.
1996 F350 AT, IDM and switched ICP mod
1995 F250 SC AT, IDM and switched ICP mod, 6" susp 2" body lifts.
1994.5 F250 SC 5spd 4x4 IDM and ICP mod
bondsman is offline   Reply With Quote Quick reply to this message
Old 11-14-2008, 08:32 AM   #7 (permalink)
Thanks For The Info On The O Rings. I Pulled It Apart And Found That 1/4 Of The O Ring Was Missing. I Will Be Putting It Back Together Today, Hope That Fixed The Problem. Note To Anyone Who Tries This.... Make Sure You Remove The Entire Fuel Filter Assembly Or You Will Never Get The 1-1/8 Socket On The (ipr) Yes, I Found Out The Hard Way!
Old 11-14-2008, 09:43 AM   #8 (permalink)
I think you could use a wrench too. I did mine about a year ago and seems like that was how got it off. I ended up having to replace my entire ipr and I got a new one through blue ridge diesel which was about $100 cheaper than ford or ih. Even though my truck did run better afterwards, that did not fix my problem though as I tested further and found I had an injector o-ring blown out that I had to replace. Just for anyone else who has to go that route.
'94 F250xlt ext. cab. ZF5-speed 4x4. EBPV delete. DPP downpipe. Tymar intake. Tymar coolant filter. Type 31 batteries. LF9691 primary filter. Electric fans. 10k mod. 1.0 turbo housing. Boost blanket. Over-axle exhaust eliminated. Electric fuel pressure gauge. Heim joint clutch linkage. Adrenaline HPOP. BDP modded IDM. LUK SMFW. DIY Elec Fuel. FS1282, FF5320 fuel filters. SD starter. DP 80hp tuned PCM.
'04 F550XL reg. cab. ZF-6 speed. EGR delete. Coolant filter. Cat EC-1 coolant. LF777 bypass oil filter. Blue-spring fuel pressure regulator. ScanGauge II. Glowshift fuel pressure gauge.
'06 F350 xlt crew cab. 5R110 auto trans. 4x4. EGR Delete. DIY Coolant filter. Cat EC-1 coolant. Blue spring fuel pressure regulator. Open CCV. SCT X4 Gearhead Tunes.
sdan27 is offline   Reply With Quote Quick reply to this message
Security Question
*Required, this field is not shown to others. "While balancing on a piece of wood, two inches by four inches known as a 2x4, john and his friend sally both spotted a dalmatian inside a truck with sirens, headed to put out a fire. State what the 2x4 is made of. "
Insurance
Please select your insurance company (Optional)
Wheel & Tire Center
Powered by vBulletin® Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
