7.3L starting problems, glow plugs? - Diesel Forum - TheDieselStop.com
post #1 of 12 (permalink) Old 12-17-2005, 01:42 PM Thread Starter
New member here, I have a 1997 F-super duty with a 7.3L turbo, now that it is cold it wont start. When I turn the key to warm the glow plugs, the relay doesnt click, and there is no power going to the plugs. The relay was replaced less than a year ago. Any suggestions or adivce to help with the problem will help.
thanks
Steve
1997 F-450 Super Duty Crew Cab Flat Bed
1974 Peterbilt 359 Custom
Steveo813169 is offline
post #2 of 12 (permalink) Old 12-17-2005, 01:44 PM
Re: 7.3L starting problems, glow plugs?
I bet your relay is dead again. Mine didn't click when it died.
96' F350 4X4. E4OD tranny running Amsoil synthetic, 1 big tranny cooler and tricumulator springs and accumulator valve. Autometer guages, homemade intake, TS 6 position Chip (tuning by
, Factory AIC, A/C mod, MBRP 4" Exaust, BDP Stage I injectors, Brakesmart trailer brake controller, T/C lockup switch
Soon to be installed: Innercooler (sittin at the shop), Big Oil, Built Tranny, Coolant Filter, HX hose, and some others. 350k miles.
TimMiller is offline
post #3 of 12 (permalink) Old 12-17-2005, 01:48 PM
Does the WTS light come on?
Partsman is offline
post #4 of 12 (permalink) Old 12-17-2005, 01:50 PM
PSDfreak's Avatar
Turn the key to the "ON" position, or have someone else do it. As soon as the key is turned take a volt meter to the two large lugs on the Glow plug relay. The reading should be VERY close to "0" if not "0". If you get a high reading...GPR is bad...
Good Luck
Casey
●4x4●ZF-5●4.10●Tymar Intake●Wildman 6 Pos. Chip●SD Intercooler●17* HPOP●4 Straight Pipe w/5 Silverline Tip●3-Pillar Zeries Gauges (Pyro/Boost/Oil Temp)●3.5" RSK/D60/SD Springs●Ride Rite Rear Bags●Bilstein 5100 Shocks●315/75/R16 BFG A/T●Pro Comp XTreme Wheels --- SOLD 01/2011
2009 F-250 FX4 - Diesel - Crew Cab/Long Bed - 4" Pure Performance X-Factor Lift - 325/60/20 Goodyear Duratracs on Stock 20's
PSDfreak is offline
post #5 of 12 (permalink) Old 12-17-2005, 01:53 PM
to clarify for Casey, he means the voltage difference between the two posts should be very close to zero. For example if the power side going in is 12.5, then the side coming out to the plugs should be very close to 12.5. Start there, then ohm the plugs. Let us know if u need more help
1995 F250 Xcab 5spd 4x4. TYMAR, 5" Mitre Cut STACKS, Skyjacker lift, 35" Mud terrains, powered by Home made Bio Diesel, Cobalt C2 gauges, DIY INJECTORS by
, 6 position chip by Fat Kid Performance Diesel(sn: house22), intercooler on the way within the next few weeks...
Nitro454 is offline
post #6 of 12 (permalink) Old 12-17-2005, 01:55 PM
PSDfreak's Avatar
thank you for clarifying...after reading my post, even I
was scratching my head a bit [img]/ubbthreads/images/graemlins/grin.gif[/img]
-Casey
PSDfreak is offline
post #7 of 12 (permalink) Old 12-17-2005, 02:01 PM Thread Starter
It comes on for a brief second then goes right out.
post #8 of 12 (permalink) Old 12-17-2005, 02:07 PM
That doesn't sound right unless its 60-70 degrees where your at. First do like the others said and check the voltage across the big terms and then check it at the little ones. Does it crank over fast? Does it smoke while cranking?
Partsman is offline
post #9 of 12 (permalink) Old 12-17-2005, 02:43 PM Thread Starter
It cranks over like it normally would if it would start, and after a few rounds of heating (or the period of when it should heat) then cranking and eventually get smoke.
post #10 of 12 (permalink) Old 12-17-2005, 05:24 PM
Do the "i gotta go method"
Turn the key on, take a screw driver and short across the 2 big terms and count about 45 seconds, then run around and try to start it. if it fires up it's probably your GPR.
Partsman is offline
post #11 of 12 (permalink) Old 12-17-2005, 11:11 PM Thread Starter
ok, i've come to the conclusion that the relay is dead, it just seems odd that within a year it already needs to be replaced, is there any particular reason that it only lasted as long as it did?
post #12 of 12 (permalink) Old 12-18-2005, 11:08 AM
Depends on the relay. Some just can't handle the high current the glow plugs draw. That is one reason I switched over to a Stancor relay. These are a heavy-duty relay and they seem to be able to handle the high current better. Click Here
02 F250, 4X4, 4R100, 3.73, B&M Transmission Pan, Edge CTS Digital Gage, Tymar 4" Exhaust, Tymar Intake & HPX & TS 6 Position Chip. IH Bellowed Up-Pipes, RiffRaff AIH delete plug, Riffraff FRx Kit. 6.0 Transmission Cooler. Dieselsite Coolant filter & Transmission filter & 203 Thermostat & WW2 & TurboMaster & inter-cooler boots. BD CCV filter. Driven Diesel Fuel Tank Mod & Pre-Pump Filter. John Wood's valve body.
Griz is offline
