#8 Injector - Diesel Forum - TheDieselStop.com
post #1 of 4 (permalink) Old 03-20-2017, 10:16 AM Thread Starter
#8 Injector
My injectors went out on my 1997 7.3 psd (California truck) and ive been reading that the #8 injector is a special injector. Can anyone help clarify what makes that injector different and where the best place to get the injectors? Thanks!
Cole Latimer is offline
post #2 of 4 (permalink) Old 03-20-2017, 12:01 PM
The injector you are referring to is a long lead injector. It was meant to help with the cackle issue found in the 99 and up power stroke engines that had the dead end fuel rail. This was a standard injector that was within tolerances but delayed the fuel shot just enough to help prevent cackle. It was a band-aid fix!! best thing to do is eliminate the dead head fuel system. Several ways to do it. First check the fuel flow in the heads, if you have a return line than don't worry about getting a LL injector. You could spend days reading about cackle if interested also.
DENNY
1999 F350 AUTO 4x4 CC LB DRW 4.10
DENNY is offline
post #3 of 4 (permalink) Old 03-20-2017, 08:49 PM
Patrick Feeley's Avatar
My Photos: (19)
Your 97's injectors will all be the same and should be that way. You don't need it. We have a regulated return fuel system on the OBS trucks (not dead-headed like the SD's). I can't make a good recommendation for where to get injectors as I haven't really kept up with reputable sources (hopefully someone will chime in on that). Cheers!
97 F250 SC 4x4 (CA model), E4OD, 4.10 LS,
, Ext Trans Filter, Tru-Cool Max, I/C Mounted but not Plumbed
SOLD: 94 F350 CC DRW, 5 Speed, SBC Con-O,
, 3 DP, Bilsteins,
, Gutted EBPV
Patrick Feeley is offline
post #4 of 4 (permalink) Old 03-23-2017, 01:38 PM
Justin@DP-Tuner's Avatar
As stated above, this was for late model trucks with AD codes (99+). Your truck should have 8 AB code injectors in it.
We can get you setup with a set of reman or new injectors if you are interested...
https://www.dp-tuner.com/ford-powers...injectors.html
Let me know if you have any questions I can help with.
DP-Tuner
For Your Tuning Needs
Like us on
Justin Bochmann
Sales and Technical Support
828-221-0076 ext.804
Justin@DP-Tuner is offline
