95' 7.3 Cam Sensor Problems Won't Start ...Help - Diesel Forum - TheDieselStop.com
Old 09-09-2008, 10:38 AM   #1 (permalink)
Stalled w/no start ...changed cam sensor. Ran fine. Started leaking fuel soon after, started cutting out like the cam sensor glitched. Would stall after startup going up a hill. Thinking Cam Sensor again. Snap on Solus Scanner read ...cam sensor circuit "torque & fuel"... Won't start, fuel in bowl....changed EBP, CPS, fuel heater element & checked 50amp fuse. Now fires w/ether..momentary firing, did few times, I know bad...fuel bowl is empty. Thinking need to replace fuel pump? Could this be my problem?
KCI00 is offline   Reply With Quote Quick reply to this message
Old 09-09-2008, 11:23 AM   #2 (permalink)
STurbo90's Avatar
My Photos: (9)
Where is it leaking fuel at? Holes in the fuel bowl are not uncommon.
If you fixed the leak and the bowl is empty, could be fuel pump or a restriction in the fuel lines, such as the selector valve.
Have you tried the other tank?
1995 F350 PSD,CC,LB,E4OD,4WDw4:10LS
IDM Corrosion
Underdash Gauge Pod
Front Tow Hooks
STurbo90 is offline   Reply With Quote Quick reply to this message
Old 09-09-2008, 11:50 AM   #3 (permalink)
Sorry, computer locked up. The bowl isn't cracked to the eye...hairline could be somewhere I guess...dunno...I'll look further. I did try both tanks. I'm working on it again as someone said I should fill the bowl up...prime it ...then try again.
Old 09-09-2008, 11:51 AM   #4 (permalink)
Good suggestion...Selector Valve...I'll look at that.
Old 09-09-2008, 11:59 AM   #5 (permalink)
No luck. I'm trying the IPR valve now. Read somewhere on a forum about a similar situation with that. Fuel pump isn't the problem either. I went ahead and changed it earlier and the bowl filled back up.
Old 09-09-2008, 01:32 PM   #6 (permalink)
Still won't start. Anyone know what kind of fuel pressure it should have just cranking?
Old 09-09-2008, 05:40 PM   #7 (permalink)
blageurt's Avatar
My Photos: (9)
Around 40-45 I believe. check to see if your IPR is still connected. Also check the 30 Amp PCM fuse , in the underhood fusebox.
95 E350 PSD HD Cargo , BB shim , E4OD , B&M aluminium Trans pan , Twin HD coolers , Cat sleeps with the fishes , 3:55 D60FF, EBPV Delete , DP flashed 60 Tow , 140 V idm , Autometer Triple pod , Bridgestone /Hankook
1977 F350 Dually Dump , 460 , 429 POLICE heads , 4:56 D70FF, Edelbrock Intake , Holley 850 , MSD IGN , Custom C-6 Trans , Dual Exhausts , Bridgestone
blageurt is offline   Reply With Quote Quick reply to this message
Wheel & Tire Center
Powered by vBulletin® Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
